That is fairly close to the max you will get out of them as is.
As stated E85 will get you further, yet they are fairly on the money for their efficient max on 98. Remembering that you have over 310rwkw, another 20 would be the most you could get (and the question is raised is that even worth the outlay?).
GL
really? that seems low. I mean I don't even have cams or cam gear. I'm at 17psi.
I did some research before buying the gt-ss and they were rated like the -9 which is a tad more powerful than -7. My friend with a rebuilt rb26 run 460whp with his -7. So, I was expecting close to 500whp
Edited by cobrAA
what country?
Im currently making 380kw @20 psi from the gt-ss turbos with the 2.8 Tomei engine kit in my gtr. My tunner said i am having problems with the electronic boost controller as it is having problems holding boost over 20 psi.
Im happy with the performance at the moment @20 psi but will eventually get a new controller for it.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
