hey for those who have bought and installed a exhaust system on there skyline im sort of interested in getting one but just need to ask in general how much it cost you to put the system onto the car (how much the mech charged), cheers
https://www.sau.com.au/forums/topic/337743-exhaust-installtion-prices-question/
Done this many a time now.
Jack the car up, undo all bolts from turbo back. I had old one off and new one on within the hour.
Be careful where you go if you choose to go the mechanic route, I had an estimated quote of 3hrs labor at $110 per hour to fit a turbo back exhaust!!
If you've got the tools and a free afternoon save yourself the cash :D
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! :)
EDIT: Cass, fit my exhaust to your car already, want to see how it goes for you ! ;)
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :(
Cat-back? Turbo-back?
If it's cat-back it's quite easy to do...
Agree. I put a new cat and a cat-back exhaust onto my gtr whilst it was on the ground in 30mins... Couldnt be arsed jacking it up :blink:
I did a full dump, cat and cat back on my r33 gtst in about 2 hours including time for the WD40 to sink in on the studs.
Cost - nothing! Did it myself without much pain :P
Need to find some gaskets first. I'm not like my brother and can tolerate driving around without exhaust gaskets for any longer than the time it takes me to drive around the block :)
Exhaust gasket cement.
um lols. i just cleaned the metal between the rear muffler and the piping forward and whacked it back together.
fiiiiine i'll get some cement and do it properlike
Using the theory that a leaking exhaust flows better than one with no leaks? :blink:
I used gaskets and cement, but originally when I installed it with AbboBob (ex SAU president), he said you can get away with vasalene if the exhausts fit up close enough, the vasalene will attract some of the carbon from the exhaust, the vasalene will then pull the carbon into any depresions and keep a hole sealed up (assuming it is only a small hole).
It worked for a year, untill I was bored and randomly decided to cement it up, I was skeptical at first but it worked for a year that I know of.
Best to do it properly though from the beginning, a good job will save you time in the long run
Call an exhaust shop.. Tell them what your interested in.. Get a price.. done..
YUp this is the easiest, and sometimes even the cheaper alternative, especially when you break the dump pipe/turbo exhaust flange bolts in the turbo flange and depending how unlucky you are you could be up for a turbo out job just to be able to drill the bolts out
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
