Need to change my turbo,so, can it be done DIY style?Is it only the 6 bolts on the dump pipe,the 4 bolts grabing the manifold,the 2 oil lines and the oil dump pipe?
Any piece of advise will be welcome...
https://www.sau.com.au/forums/topic/338555-turbo-change/
9 bolts holding it in place ( dump and manifold) undo them without f**king anything and its a matter of 2x 24m i think water banjos and the top oil feed bolt which is a 15m i think... the bottom oil drain should just pull out if u take off the clamp.... change over is simple... but the work after like tuning etc.. for the new turbo u cant do well unless u tune cars for a living.. lol
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5470766
Have a look in the DIY/Tutorual section, there will be something over there, something like R33 turbo into a R32 is a common tutorial. I know it's not a stagea but it's basically the same thing.
Give yourself a couple of days to get it done in, just in case. Think about soaking all the turbo bolts in some WD40/Inox/CRC the day before pulling it down, and if they start binding up coming off wind them back on a bit, give them a spray and slowly work them off. Its also a good idea to change both the gaskets to the turbo while it's off. Just take it slow and steady and it should be relatively easy, start rushing the job and your bound to stuff it up.
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5470844
+ 1 on changing ALL gaskets while its off. Dont skimp on them, the last thing you want to do it change gaskets 6 months down the track after all this hard work.
remember to remove the water and oil lines BEFORE you try to take the turbo and manifold off. many people dont and bend the lines too much and they never go back. if you can stretch the budget, get a set of braided oil and water lines. well worth the money and trouble.
when removing the manifold. dont take each nut off one at a time. do them as per the service manual, there will be an order that you should remove the nuts in. this will stop the last nut from getting stuck.
if you find its pulling out the stud with the nut, just let it come out, youre not going to break it. you can put in a new stud.
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5470873
Did mine with the help of my old man a few years back (ok, actually, he did a majority of the work...). It's a fiddly and time consuming job, but not hard in a technical aspect. I think we did it in about 5hrs, which is not bad considering he'd never worked on anything with a turbocharged car before, despite 40-odd years of tinkling with cars in just about every area except major electrics or auto boxes.
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5471621
Thanks,for all the answers...though that the water/oil lines were the difficult part as I already changed my dump pipe so the main difference are the 4 bolts holding the turbo.
It really happens in a bad moment ,I need to get the 100000 Ks. major service and the brakes(started to get parts to do the R33 swap)
Every thing happened at the same time...but think that turbo is first cause I feel like driving a vacum cleaner...and all the options but short of cash(get an R34 turbo,send mine to be fix,pry and wait until somebody gets rid of a hi flowed/hi performance one at acheap price)...
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5471709
I've done it and yes it was a PITA. That 24mm banjo was the worst. Had to get a ring/OE and cut the ring part off and use a tube for leverage. Dont forget the lock tabs for the turbo bolts. An absolute must. Lots of WD etc if you take the manny off. I boke 4 studs and one , at No6, was not there. If you break studs you can get a mobile guy to come out. They drill with left hand bits which tend to ease the broken part out.
Before you start get a big pak of Band Aids.
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5471761
when i did it someone suggested a technique to use and i dodn't brake anything
if the dump bots start getting tight, just go back the other way for a turn or so and give it another go
add some wd40 when that happens too
and wd it well in advance too
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5472449
Yeah, those RB studs are a weak link. Dont forget if you do break a stud you can get the mobile "Stud" man to get them out. As I said before a local, yep on Mt Tamborine had all the good left hand drill bits. And he got them out of the block with the motor in place. Big relief,
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5473322
i worked out a good technique when doing the rolla gt25 hiflow diy.
I had a bolt with a washer head that was hitting the dump and didnt have enough clearance..so i angle grinded it off.
and i found it was best to get fresh studs and nuts from preferably the turbo shop to match your own.. then put two nuts on the one stud to tighten to the correct area (and dont forget to put locktie quick release goo on them) and the same again to get them off.
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5476138
  • 4 weeks later...
Now turbo is out and just waiting for it to come from Hypergear...two question ;can I reuse the T3 gasket? and how tight do the bolts that hold the turbo to the mani should be?they were nearly hand tight when i took them...
Thanks...
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5521151
Thanks...
i suppose you could reuse it if its in ok condition, i just that you can pick up a new one for around $20 so why not change it, it would be a real pain if you had to pull it all off again to change it out if it doesn't seal up properly. the nuts should be up tighter than that, but they do work themselves loose over time (and by time i mean years) with the heat, thats why the locking tabs are on there.
how did you go removing it all, easy enough?
Edited by QWK32
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5521267
did a gt25 highflow on a 1.8l rolla sportivo recently.. and it wasnt a hard job.
but fwd so the turbo was easily accessible.
stock ecu handled it also.. didnt go too nuts in the highflow no boost cut , or detonation.
t pieced to 18psi.
reused all gaskets works fine.
43mm inducer to 48mm
on the intake side.. cant remember what the zorst side was but it goes fantastic for a shitbox.
Edited by PetroDola
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5522062
Replace all studs, nuts and washers while you have it apart. Otherwise the ones that survived the disassembly will snap when you put it back together...
toyo wanted 186$ for the zorst gasket and 92$ a bolt. dump and turbo manifold gaskets were around 100$ also ....that happens when theres only 110 of them.
i got 4 matching studs and nuts to replace the turbo/dump ones that were crusty and got them from mtq for nothing (they did the hiflow for $1400 )
toyo also wanted 5k to replace the stock ihi rb6 turbo when i asked them out of curiousity.. which was stupid tiny.
oh they also wanted $1687 for a replacement turbo zorst manifold because one of the headers on mine spat a hole.
welded it for $80.
absolute jokers.
ill be diying the stagea turbo also.. stuffed im paying someone else.. who will do a half assed job anyway.. so what if it takes a few days longer.. least then you can make sure its done properly every step of the way!
c34 will be a sinch also compared to nm35's
the "engine out" vg30 legacy lives on in vq!
Edited by PetroDola
https://www.sau.com.au/forums/topic/338555-turbo-change/#findComment-5522087
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
