Hi all.Was told by a reputable worskshop and tuner on the gold coast that unless i put a orc twin plate clutch or similar in my R33 RB25 which will soon be running arond 270 rwkw that only a twin plate will stand up to the job.Running an Apexi ax53b7025 turbo.I am planning on taking the car to the drags to see what it is capable of.Other than that it will be my weekend car and am planning on taking it to events such as powercruise.Does anybody think a heavy duty of some sort or a Jim Berry clutch would be up to the task?I was Quoted $3000 for the ORC twin plate but i can not afford it at this point in time and not in the near future either.
https://www.sau.com.au/forums/topic/339468-twin-plate-or-bust/
I'm currently running a single plate organic (custom built by a racing shop in sydney) on my GTR. 400kw atw and does not slip. Been on for a year at that power level and yet to have any issues. I get them through my mechanic here in brissy, pull type on a GTR is $1350 and $1250 for a pull type. If this sort of set up interests you send me a PM and I'll see if I can organise one for you.
Andrew
After doing some research,either a Jim Berry or what joeyjoejoe's running.
Currently running an Exedy heavy duty uncushioned ceramic single plate on my car atm. 297rwkw for nearly 12 months and the clutch has not slipped once. I run the same gearbox as yours so if you're looking for the exact same clutch then the part number is = NSK-7056HDB. Got it through a mate, can't remember exactly how much I paid but I'm certain it was around the $450 mark. Brand new, came in a kit with new thrust and spigot bearings.
you can certainly go harder than that though
I run the HHHDB and it's really pretty easy to drive and will take a LOT of punishment
i got i wholesale so have no idea of the retail $
Who needs twin or even triple when you have a Jim Berry single plate?!
A friend of mine has over 700awkw in his GTR and has drag raced the car for over 9 months. No dramas.
Getting rebuilt now at a cost of $500!!!
Best value, best performace clutch in the world hands down.
Same clutch is in my car and will never look back. Almost stock feel too.
had a $300 clutch (2500lb organic) made by a local mob that handled 250rwkw for a couple of years, was still fine on the street and was very nice to drive but slipped at the drags after a hard launch. now got a 3000lb ceramic from the same place for $450, will see how it goes with 300+rwkw and 30det torque
definately no need for $3000 twin plates
Edited by JonnoHR31
Call Dan at Elite Racing on 3807 2789 he will get you somthing from NPC which is usually cheaper than Jim and uses a pressure plate that is less inclined to grenade in a dangerous manner as Finelines Jim Berry did
http://www.skylinesaustralia.com/forums/Cl...on-t233996.htmlClutch explosion link
Yeh,i went and talked to Dan last saturday and he walked me through my options and we decided on a combo he uses in his race car.Just gotta plan a good time to book it in.
bloke builds thousands of clutches and has an issue with one and you blokes cant get over it.........i dont understand.
Nismo twin plate... would never use anything else.
ran one in my gts-t with over 350hp lots of track work (lots and lots of drift e.g clutch kicking) took the clutch out and it looked brand new had been in the car for atlest 3years.
was very streetable with no rattle and not super hard, was easier to drive than my old 5puk button clutch and alot nicer on my gbox/drive-train
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
