rear screen -OUT!! looks like its been out a couple of times as well. it actually was EASIER to get out that the front.
I'll do the clean up of the channel tomorrow. bit late now to fire up a grinder and air compressor. (shop backs onto a residential area.)
side glass - out!
shame really. when you pull these things you destroy the seals. I have two perfect pieces of glass and no seals.
on another note:
my new sill panels are here. I'll pick them up over the next few days and snap a few piccies.
i have a few other bits of steel to buy as well. the brace between the drivers front strut tower and fire wall has to come off. there is a small amount of rust directly under it that I can't get at so I am going to replace it as well.
a few progress images
front window channel. the top/bottom corners of this had surface rust. I have wire wheeled most of it back to a shiny surface.
the panel where the hoses are gets replaced. where the firewall panel meets it there is rust under it.
other side. lower corner had surface rust.
passenger side bonnet hinge mount. small hole there - nothing a bit of brass wont fix.
never worked out WHY this happens on these cars. had several cars over the years like this (see middle of channel) only thing I can figure is that when the glass is out and put back its not clean enough and it doesn't reseal properly.
other side - same issue.
the areas around the boot lid are fine..
this will be the final product once I'm done with it - yes its that one is a GTR. Thats what the front of mine will look like. (thanks to ken for the shot!!)
Great to see someone giving a non R32 GTR some love.
One of the few things i couldn't seem to get from Nissan new was the boot rubber stops, apparently they are discontinued otherwise its amazing what you can still get, managed to pick up a brand new clutch pedal spring for a previous build.
You have some way to go so goodluck!!
yet to try actually. I know that if they are NOT available I will use them off another nissan. thing I also found was I could not buy new for MY chassis are the door catches. though another fellow I spoke to had no problem getting them.
true but thanks to those that are restoring GTRs it makes my parts a bit easier to get as nissan are still making them and as long as people are buying parts I can get what I need :P
The striker plates that the door itself latches to ??
I brought some from Nissan only 2 weeks ago, they even had them in stock. it was for my partners GTST, but i can't see a GTS4 being any different, that simply wouldn't make sense.
yep. I gave them the part number fast spat out and it came back not available for mine. I'm going to try another chassis number.
I ordered a NEW GTR front bumper this morning as well.
given the second hand prices on this forum and what some of the parts guys want for them I figured new was a btter option. as such I'm starting at the front of this car and working back same as the parts book does.
passenger side inner sill panel - this is a byproduct of a 50mm crush from a hoist.
outside passenger sill. 50mm crush.
better shot.
if you have ANYTHING like this on your car look at the inside behind the carpet. it was the first thing i did when i bought this car.
drivers side. 75mm crush. this was actually hidden by a side skirt. the resulting damage on the inside is far worse as it has also moved the floor up 25mm..
another shot.
drivers rear - this one actaully broke the seam.
inside drivers sill.
bear in mind ALL of that is coming OUT and being replaced with NEW parts.
you are a braver man than most. seems like quite a low base to start from.
probably (though slightly nuts may be a better description). last car I rebuilt I spent more on for the base and spent a LOT more time/money on doing what it needed done. thought I would start cheaper this time and totally rebuild one.
the sill shots are 4 pieces of metal totalling about $1k. those will fix all of that mess pictured. the rest is fine. considering the car sat outside in someones front yard for 8 months I was prepared for a worse outcome. all worked out ok and some of the stuff I haev sold off of the car has went back into other aspects of it.
minor update from the land that never sleeps (japan) - I have a 09/97 4wd RB25DET with 100K on it heading this direction. due end of january I'm told (its sitting in a mates yard in osaka.). that will need a tidyup before It goes in but at least I have one now rather than scouring the countryside for a broken one...
started picking up my parts from nissan
new inner guards (these are GTR btw)
63842-05U80 - guard protector - RT $160
63843-05U80 - guard protector - LT $160
inner sill - right side.
76450-01U00 - Sill inner - right $190
the outers are more again. they are sitting at nissan waiting for me to pick them up.
ordered a few more bits today.
NEW undertray, (which I'll have to modify for the brake ducting.)
corner brace (panel behind strut tower drv side.)
charcoal canister holder
intercooler air guide. (I'm using this as a oil cooler guide.)
spent a bit more time on it tonight removing the inside sound deadening and pedal box. all of this is in aid of me cleaning the engine bay out so I can take a scrubbing brush to it.
also found a neat mod for the drivers central locking. the side door actuator out of a E50 Elgrande fits nicely onto the R32 catch and gives me electric control of that side. I have to build a harness for it but its a lot more reliable than an aftemarket item.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
