yep. part of the reason when I get to that point the seats/panels go on a truck to MLB (or if its around Oct I'll take them myself.) if anyone can find what I'm looking for this fellow can.
start of rear guard removal. most of it was hit with an angle grinder to get it off.
rear guard section. that took the fuel filler mount with it when it came off. that mount is not part of the guard - it is an extra piece.
rear wheel arch -inside. the rear area lower is almost non existent. panel shop is aware of it and has already worked out how to fix it.
the other side is fine.
still need to remove the sealant around the fuel tank hole
inside view of the lower rear guard - all of this crap is what caused the thing to rust in the bottom corner.
if you have crap like this in your's - clean it out!
this has been cleaned with thinners and ground clean. there is a ventilation duct that sits in the void. the small hole in the top left was a screw.a bit of brass will fill that. the lower white seam will need to be resealed.
more guard removal - the weld mark is where the cut n shut was done. the people that did it certainly liked the stick welder.
close up of bog used on that side. there is 3-4mm there. that is all gone now.
removal of the ORIGINAL panel (top area) that was welded over. once the new ones land it will be done with brass to hide the seam.
original panel gone. note lower area. this was the result of two things: a misplaced sunroof drain and incorrect jacking. I am going to make a hole in the new sills so that the sunroof drains out to the ground and not into the new sills.
close up of the top area showing where the factory roof/guard seam is. cable ties are holding the build plate for the car. I do not have a safe place to put it at this point.
closeup of lower area showing rust from sunroof drain and incorrect jacking. that sill had been replaced once already.
another photo of the crush and where I cut it loose
the above section of panel removed. note rust on bottom.
panel off showing sill damage and rust because of it.
this was the cracked area that is visible quite a few images back. note the build up of crap behind it. at that point the only part of the guard left is on the B pillar.
rear area prepped and ready for new panel. the side window area and rear window area have also been done.
this is how it sits when I'm done with it for a bit. looks bad in the work shop otherwise. great talking point though once I pull the cover off.
Ordered a couple more small bits today. Fig 78120,78126.
those are NOT part of the rear guard.
in addition to this FIG 78111E & 78100B are also not part of it. 78111E is no longer available new from nissan. I have mine still and its it perfect condition so I will cut it out of the panel and reuse it. I am going to wait on Fig 78100B and see if it is part of the guard. the diagram says otherwise but seems most things on this car are getting revised as it ages.
part numbers for those playing at home:
78120-04U00 - Base Filler lid
78134-04U00 - corner rear fender RH
78112-04U30 - fender rear RH
the first two are cheap at 30 & $50 each. the rear guard though not cheap. $700+ ! yet to order it.
roof panel is due about the 10th or so of may.
had the panel guy out today for a 45 minute chat about the car and what else I needed to do with it. from my side (removal of things and buying new parts) I'm just about done with it. I can't drop the sills off until I get the car to the panel shop. if I do it before hand the thing will be a pretzel and lose shape.
GT motors is quite impressed at what I am doing and how I am pulling it down a piece at a time. to be honest I'm learning a fair bit as well by doing it.
I know now exactly how the car was put together and where all the seams are on it.
to those that call me a mad man - nope determined is the better word.
wait till you see what I do with the inside of it. :)
remnant of rear guard. spoke to the panel shop about removal and was told to be precise and punch through every spot weld on it (I have found 6.) and it will slide out.
area around rear guard removed. it has been sectioned when the side was done. rear area has to be rebuilt.
close up of rear area. a lot of crap fell out of that when I ground it off with a grinder
forward B pillar - stray metal removed and prepped with copper paint. the lower sill scrap can stay there for now. the main area I wanted to clean was the painted section so I could see where the sill was and how it fits into this giant jigsaw puzzle.
as it sits now the outer sill is first, B pillar panel second and inner sill 3rd. the outer is going to be easy to get off. the inner one I'm not sure on until I get started in the outer. car has to go to the panel shop for this part of it. I am doing the removal but not at the risk of it folding like a pretzel if I do it in my workshop and THEN move it.
quick note for those tossing GTR tanks in a GTST body. the rubber bung (to the right of this image) IS THE STRAP MOUNTING POINT FOR A GTR !
that makes my patch job a bit easier as I do not have to worry about strength on that point as the mount needs to slide across a hole.
fuel strap support removed. that hole was under it (see a few images back) and as such it will be sectioned out and replaced with a bit of steel. the hole I need to use is covered by the steel brace.
rear shot of removed fuel strap support. that is the other side of the rust spot.
this was a right royal pain in the ass to get off. one layer of steel over it and one under it. it did NOT help that it was welded in place from the top down. see next image for a MUCH better explanation.
there's not a lot left in that top corner. I'm in two minds here. ENTIRE rear shelf or a steel plate. body shop can decide there.
the top corner of it was ALL weld not a scrap of steel to punch through and remove. the back end of it was 4 spot welds and it came loose. the top left that mess when I removed it.
its a new radiator overflow bottle. there is a trap when buying these things: you can buy the bottle/hose, you DO NOT get the yellow cap. that cap costs $10 extra! bottle cost is $170.
I have a brand new cap you could have for $0 but I guess too late now >_<
spoke to the panel shop today about the mess in the right rear corner of the window - it was suggested that it would be cheaper (labor wise) to replace the rear shelf than it would be to make a patch for it. I tend to agree myself. this is another panel that stays in place until the car goes to the panel shop. given that it ties the middle of the car together I'm not about to remove it just yet. there are 45 spot welds on it that will take me about and hour or so to get off.
part number is : 79400-04U30 for those keeping track
for those that want to check - this is what the rear seam around the boot is 'supposed' to look like. if you do not have one there is a VERY good chance that yours has been crashed and you have the problem I am faced with now.
tape measure showing length of 'caulk' seam. this is mainly for my reference so the panel shop has a reference to work from.
picked this up today. its a GTST item and now I have a full set of reverse lights that are not cracked. the inner mounts are intact as are the steel brackets that hold it to the body. see the next two images for a better description
image showing damaged mounting points and torn plastic tabs
close up of the steel brackets/plastic tabs. 90% of these things are rusted (right side) or the plastic mounting points have been sheared off. in both cases it makes the panel almost useless.
some new bits: the left one is the lower rear right corner brace for the boot. the right one is the fuel filler panel. this is an addition to the rear guard and not part of it.
I also ordered the rear boot panel today as well. it is a LOCALLY kept piece out of MLB.
the rear shelf is next to order and that too is a LOCAL piece. It seems local support for this car is great!!
there are $90 worth of bits there.
closeup showing part number
close up showing part number
God almighty she is in rough shape... credit to you mate. Great work!
give me 6 months :)
the interior arrived today for it , the engine arrives on monday from there it's a case of reassembly once a few more panels arrive.
spent some time tonight unpacking a pallet of stuff. two boxes , carpet,boot trimmings and lots of panel work. all of it out of a 89 GTR that could not have been over 38-40K old. every bit of it was clean as and I have put all of it away and in boxes. dash included.
it was a far cry from where I started and once the body is done/painted it will go in. purchased it off a SAU NSW club member. cheers pete :)
I also started stripping the mirrors down and bagging the bits. if I can get the paint off without destroying them in the process then I will start cleaning them up. I have to find new mirror glass that is FLAT glass. I think that is going to be fun
in the thick of it Chris....
nice to see regular updates.. i am an avid follow of the tread
you got to see it though. most are not that lucky.
I will say one thing at the end of this build. if anyone door dings it I will probably kill them.
as am I. I will be doing test fitting on the majority of it. the drivers side should be easy as all of it will simply line up as the factory built it. the passenger side I think will be interesting. I still have a factory fitted guard there and getting it loose without destroying it will be the hard part. I'm not keen on doing that one as well when there is nothing wrong with it.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
