Still following your fantastic build. When you get there, I think it deserves a better than GTR spec engine.
nah, RB25 is fine. the mechanic I share my building with had to do a mazda MPS6 and the turbo job on that was $5k so a rebuild on a set of GTR turbos would get close and that is som thing I do not want.
also if you need a 4spd auto for yours I have one here.
started rubbing the surface rusted areas down with rust converter. did that before I left the shop and I'll clean it off early in the morning. took a few piccies as well. the next few weeks are going to be dedicated to cleaning the shell up (low on extra $$) so I can get it ready for the panel shop.
also found where the sills were cut in as well. there was a LOT of f'glass and filler in the forward areas around the outer drivers kick panel area. ground all of that out and it looks OK from a removal point of view.
one thing I negated to mention. doors are now off it. didn't realize that they were that much of a hindrance with them in place. I now have to find a place to put them.
new interior. that's pretty much all of it. the dash panel is at the shop wrapped up in a box. the plastics all have a think coat of Armour all on them. all of this came from a 89 GTR wreck.
the boot trim is not there but it is in great condition as well. I have ALL the bolts/screws/snaps for it as well.
The carpets are in quite good condition and I am still trying to find a way of storing it OTHER than folding it up..
original gear boot/radio trim panel. my original one was split in three places.
original handbrake trim/armrest panel. I'm impressed as most of this stuff is OVER 20 years old!
more new bits. this has been covered in armour all to keep it from drying out. these are the panels around the column. there was an alarm in the donor car (top left panel has a bezel in it.) and I'm probably going to replace that panel at some point as I tend to put my alarm LEDs in another spot. (the current idea is to find a security indicator out of a 90/91 mamixa and drop that into my dash.)
pictures do not really show the condition of these. the light spots are the flash. they are damn near new. aware of the $19 ones on ebay fitted several to customers cars.
have the lower GTR intercooler mounts now. seems very few people (wreckers) know that these things come off the car. mate of mine was scrapping a nose cut and I noticed them on it. 6 10mm nuts/bolts later they were mine. rubber mounts are missing though :(
got this tonight :
32 GTR rear bootlid and wing. did a contra deal with a mate of mine.
another view
now if I can keep doing contra deals over the next few months I should have a lot of this car back in one piece :)
tossed the boot lid on the car this morning
GTR boot lid on car
second shot
these showed up this morning. one full set of 17x7 Nissan BBS wheels. these are off a C34 260RS. tires are totally screwed but good enough for me to get an eye for tire size. I'll swap the centre caps to skyline ones once the car is finished. this was another contra job for a importer mate of mine. (ESP imports.)
quick update and marking off of things
engine at this point will be a RB25/30 with a PFC on it - WGNC34 RB25 with full harness - purchased.
Front end - GTR. I am doing this simply because somewhere over the last 21 yrs someone cut the front mount hole out of the drivers front area. so I may as well use it.
IN PROGRESS.
R33 intercooler purchased, R33 trans cooler - purchased, lower IC brackets purchased, GTR bonnet and front insert located. FRONT bumper - purchased.
brakes - R34 Brembo front and rear - STOPTECH front/rear brakes - located not yet purchased.
Interior - stock GTS4 - the seats are in good nick and after being given a few 32 GTRs for a week at a time I'm not really a fan of the seats for daily use. - Interior 90% done. still need to fix seats and get floor mats.
Wheels - 17" of some OEM variety. would like to do the stock 16"s but clearance on the brakes kills that idea. - WGNC34 17x7 260RS wheels - contra deal.
stock nissan radio from a Y61 Patrol. yes I own a car audio business, yes I caould have put what ever I wanted :P - I chose a stock radio for a reason - theft. no one wants them and this one supports a CD changer which in my case will be an ipod controller. so I have a radio,cd,tape,ipod. it does what I need. (I'm old and I have a car with a big stereo in it already) If I decide to do a sub in the car I will modify this unit. I have the 2114 schematics for it courtesy of clarion.
top shot showing model number. PN2114 is local PN2135 or PN2198 is Jap. internally they are the same bar the Tuner front ends. there is a doide setting that changes the firmware over to the appropriate model.
I have a 2198 at the shop that I modded to local but it has a drifting problem and wont stay on the station. (PLL isn't locking.) I found it easier to find a local unit and use that due to cost. (the 2114s are 10/11 years old and worth next to nothing.)
other reason I have this radio. it matches everything else in the car and I do not have to rewire it to suit the car.
looking at brakes :
http://www.powerslot.com/partsapp/details.php?id=759&makes=11&models=1241&years=1989&categories=22
they do a 6pot one as well. if I went that route though it would be more for looks/wow factor than actually stopping.
GTR boot lid on car
second shot
ive got a burgandy gtr bootlid + spoiler, want to swap for your black one :P /too bad not in Vic!
Ive heard rumours that the gtr bootlid doesnt sit flush on GTST? Can you confirm. How is the fitment?
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
