Paul Lewis has gone soft on us.
Best wheels I have seen. If they are as light as you say Pauly and still strong then they ae the BOMB wheels to get. I doubt as strong as RE30's though.
The blue groves are machined out of the black chrome and anodised, and yes depending on the angle depends on how much blue you see. They do their best work in motion, the blue comes through as a glow from behind the wheel. I have not seen it yet but the misses said it look like it has a fluro light behind the wheel.
Cassowary - large flightless bird that can run fast over 50km/hr and jump as high as 5 feet.
Noticeable by its iridescent blue body parts.
http://www.kidcyber.com.au/topics/casso.htm
Nice blue!!!
Noticeable by its iridescent blue body parts.http://
Bloody scary too! A mate of mine was baled up in a toilet by one while on holidays in FNQ. Reckoned it was after his toes! (Wearing thongs)
John,
I chceked the weds site, the SA-55's1 8 x10's are 9.2kg's
I googled RE30 weight and found the following, 19 x 8 = 8.75kg
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
