Hi Guys,
I bought a 99 V spec R34 - in the process of modding. I bought a Sunline Racing 76mm Single throttle body - and brought in the Greddy intake plenum - but I see the plenum is for multiple throttle bodies only. Who makes an intake plenum for my car that bolts on with a single throttle body setup ?
On a side note, thanks to Dan for sending those LED lights all the way to South Africa for my car. I will post pics once my car is complete.
thanks
Darren
https://www.sau.com.au/forums/topic/340599-r34-intake-plenum/
why would you change from the factory setup?
most Aussie places have single options, however the 6 ITB setup suits 99% of people.
what's the application?
running a Garret 6262 with .81 AR single setup. I'm concerned about getting enough flow to #6, so want an enlarged plenum and throttle body design. Also going to be the first one running a Haltech unit like this in the country, so not sure what to expect really.
I can give you full spec list of what's sitting on my floor if you like, and you guys can critique it.
no, it will be more track oriented. I intend squeezing out 1200hp on the build eventually, and don't feel like purchasing new parts every time I go up a level. Did that too often with the Scooby and Evo, and end up paying tons in school fees instead of doing it correctly the first time round. You think the stock plenum will suffice for 600hp for now ? And is the haltech 2000 system better off single throttle configuration, or 6 throttle, or doesn't it matter ?
so its a drag car predominately?
get a hypertune plenum and hyper tune single throttle body.
f**k off the haltech and run a wolf v500 or a motech system
1200 hp for a track car is ridiculous lol thats serious drag territory and i hope u have really deep pokets lol
standard plenum and cooler will see around 350kw or so, so no not 600hp
600HP on the factory one for now, certain not an issue and plenty of people around that quite comfortably.
ECU, not 100% sure but given your location the issue of tuner and stuff would suggest to go with whatever is recommended for best results :)
1200HP is just a tad ambitious though for a circuit car...
plenty more important thing to attend too than outright power that will keep you spending serious money he he :)
oh come on, are you really serious?
you have no idea what you are talking about mate. lately all your posts are just plain rubbish.
there are PLENTY of GTR's on this very forum making 380-400rwkw, factory cooler, factory plenum.
the ones here in Vic, setting some stupidly fast circuit times to back it all up.
I know heheh, I'm a power whore. Had a 500hp Evo on stock internals - pockets not a problem - my lack of brain power is lol. Just interested in toying around with the ecu. Impressed with Vipec, just not sure of its capabilities with Skyline. BBK and suspension parts have all landed already. Manley turbo tuff rods and CP pistons here - and then pretty much complete tomei internals. Will run dual external pump setup later on. Custom built oil coolers, radiators, oil coolers already done. I want to track the car once it's around the 600 mark, and then ultimately set up another block for 1200, based on what I'm learning with the current block. Custom built exhaust manifold done, and all gaskets, seals and belts are ready for replacement. ATI damper already here. I'll setup the car info on the other forum, and you guys can agree or disagree with the build thats starting on Monday. Please feel free to rip me apart - we don't have many skylines here to learn from, so most of what we do here is through trial and error and internet surfing.
Nismoid,
Just out of curiosity, wouldn't a major contributing factor in my case be the fact that I'm so high above sea level ? (based in Johannesburg). Would I still be able to do all that with the factory setup ?
LOL WAT?/!
Darren -
How high Is JJohannesburg?
Here In canberra we are fairly high and have cars making 2000hp in Dyno comps.
Thats the best part about turbos...just add another couple of PSI and the altitude problem goes away lol
ignore all this.... for starters only an insane person would swap out a haltech for a wolf.... in fact i would rather gargle glass.
I knew you would poke your head up when Wolf came up...Do you search that word when you log on LOL :D
zebra - Johannesburg just under 1800m above sea level. Really slaughters our NA cars up here.
thanks for other info so far guys - I have source a nice plenum from RIPS complete with a 90mm TB. And I've ordered a new vented coil pack cover from Joe at Powerhouse as soon as they finish with it.
is the HKS twin magnifier worth the spend ?
Wow that is high!
You will be happy with the RIPS plenum, they make good gear.
  • 4 months later...
Hi Guys - just a quick update....car was finally licenced in December last year.......even though all my paperwork was correct - it still took the government 8 months to licence the damn thing. Customs has been clamping down heavily on imports over here, and confiscating vehicles to the value of millions every month at the moment. Anyway, here are a couple of pics - block is built - just a couple more custom piping issues and then the run in and tune - going for 50/50 mixture with eth.
This block determines the big build - just trying to work out many headaches, and since we don't have many skylines over here, everything is a steep learning curve. For now this setup will only run a 6262 .
Edited by cruiser1
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
