i've never owned a turbo before so i was hoping someone could help me out a little..
im running a completely stock 34 gt-t and sometimes on ignition the boost gauge won't move, not even a slight fluctuation, today i was driving and the gauge had been sitting on nothing, then doing 60 it suddenly jumped to about midway up the gauge, stayed at that pressure for 10 seconds, then dropped disturbingly quickly back to 0, im not sure whether it's because i've only started looking at the boost gauge while driving that i've noticed it goes for ages without moving from 0, i can hear the whirring/spooling? sound but without gunning it, cant tell wether it's active. i had a major service (smooth garage) and immbolizer installed friday if thats relevant at all..
basically i'm dumb, is there something wrong? or is that normal behaviour? only just bought it, i'll be pissed if it's already playing up. :whistling: is my best bet getting a compression test?
cheers guys
https://www.sau.com.au/forums/topic/340898-faulty-turbo/
cheers guys
Sounds like your boost sender has a dry solder joint or its your guage. dosent sound like the turbo its just the electronics
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502907
+1
Don't panic just yet. Get the boost gauge checked out. :whistling:
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502912
34's quite often have dodgey sender units dont they?
If that is indeed what it is, dont panic at all, its a 30 second fix.
BTW, to the best of my knowledge, a turbo wont intermittently boost, it either will, or wont, not both.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502927
thats what i thought, is there anyway i can fix this myself? i think supercheap has 60mm gauges i could grab but installing it would no doubt be a nightmare >__< gauges are half the fun of owning a turbo imo
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502937
I recently re-soldered the dry joints on normsta's boost sender that was doing the same thing.
If you're comfortable with a soldering iron, it's about a 15 minute job to take it out, hit it with the soldering iron and put it back in.
The other thing that normally breaks about the same time is the vacuum hose back to the plenum. It'll often crack when you try and pull the sender out to replace anyway. I'd suggest try changing the vacuum hosing and then if that doesn't fix it, look at hitting up those dry solder joints. It's the three main ones coming back to the plug. There's a thread on it somewhere if you hit up search.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5502942
i'm in croydon, i found a tutorial about resoldering the three joins on the chip above the front right tire, scared about messing with it, it's under a three month warranty, doubtful but would that cover this?
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503032
yeah take it to Jenna save some money and she can show you some things about your car :(
uhhh .. what's a car .. I'm just a girl :whistling:
You could ask them - couldn't hurt to give it a shot. :blush:
It's pretty easy to do if you have access to a 10mm spanner to unbolt it, and a soldering iron to re-flow the three joins though :P
The hardest part is undoing the damn clips around the edge of the sensor, I always struggle with that bit.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503038
to update, i've checked all the cables and the vaccum line as best i can, all in good working order by the look of things gonna try and pry open the boost control chip case and go from there.
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503138
managed to get a hold of a soldering iron but i can't seem to get the boost unit case open, i don't want to crack or break it but can't seem to find a way of getting it off
edit:
i mean the larger case just above the right wheel, not the part sitting above the engine
Edited by trappedunderice
https://www.sau.com.au/forums/topic/340898-faulty-turbo/#findComment-5503254
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
