I am looking at going down for both days as really need the seat time after having not driven my car in anger for about 3 years.
I will be sorting accommodation in the next 10 days so if you are coming down then may be able to sort accom
http://www.piarc.com.au/files/Nov%202010%20Sprint%20Regs.pdf
I just need a 1:51.9 and I will be stoked :P
https://www.sau.com.au/forums/topic/340973-piarc-sprints/
  • Replies 49
Mmmm. so tempting! I was planning on going to the SnS though...
My issue is that I have slotted brakes that don't have slots anymore! and need new pads...
I was hoping that winton was going to be my last blast with these brakes so I didn't need to spend any more money on this setup before I put on my G4s.
PI is hard on brakes right? or does the flowing corners mean less big stops?
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5504004
Its fairly hard on brakes, esp into Honda. i think its only right that you set a decent time there before you go and turn your car into a sports sedan, i wanna know how quick you are round there :) Would be a good comparison to compare to when its done too.
Piarc days sell out fairly quickly right?? how late can we enter??
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5504165
Yeah I might head down for the Sunday.
I wanted to do a Sandown day before the year was out, but time didn't permit, so this might be the only option for some track time before the year is out.
Luke has entered the S14 for the Saturday.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5504199
Looking at the entry form. Are we class H? Over 3000cc modified?
Cash on the day coz I don't have a cheque book?
There is nothing about it on their website.
Yep only the sun for me bris...assuming my entry is accepted.
Russ, the classes don't really matter as it is more for the PIARC people doing their championship thing I think. I believe the turbo multiplier puts us in the over 3000 classes.
Cash on the day should be fine....was last time I did a PIARC day.....if you want confirmation email the event sec Teresa at [email protected].
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5510172
i'll get my car running first. ive pulled all the epa un-friendly parts off of it. if i go, i'll be going with just a exhaust and cooler. which would be good in a way, as i wanna go just to suss out the circuit.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5512614
quick question re scrutineering.
they say 2 bonnet secure methods, are they insisting on bonnet pins ? aiming at older cars that don't have a spring catch and a lever'd saftey latch
it ain't obvious! and i'm considering the saturday event.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5514877
It means 2 'methods'. The standard latch is only 1 method.
Pins or a belt will work.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5515379
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
