Hi,
today i come on to edit some of my For Sale posts and the edit button at the bottom of my post isn't there. i posted a new reply to the thred today and the edit button is at the bottom of that one, just none of the other older posts i have made.
i have two For Sale topics at the momoent and cant edit either of them, so its not a problem with just the one topic.
does anyone know or have any ideas as to why this is? the help would be appreciated.
Thanks
Josh
Edited by QWK32
https://www.sau.com.au/forums/topic/341192-cant-edit-posts/
You could just post up again with the updates?
People reading the thread will see it.
Reason being we have dodgy traders editing thier posts so its harder for us to track down goods sold, what type and so on.
fair enough. will do from now on, thanks.
https://www.sau.com.au/forums/topic/341192-cant-edit-posts/#findComment-3825596
I also had this "problem"
Can the 2 hour thing maybe just used in the For sale sections? It's a real pain in the a55 if you've made a spelling mistake or said something silly in another section :rofl:
Shouldn't say some thing silly in the first place :P
https://www.sau.com.au/forums/topic/341192-cant-edit-posts/#findComment-3827076
How does freezing the post stop bad traders? All i can imagine it doing is shortening the life span of their login.. which means they just have to work a bit harder to cycle their logins and get them ready for posting.
From both a buyer and seller perspective it makes the Parts for Sale Section harder to use. Adverts with multiple items can go on for weeks and have a lot of responses. I will normally continue to edit my first post to make it easy for people to get the most up to date information. With the lock in place people will have to scour through the whole thread before they know if they're wasting their time. One might then think to post separate items in separate threads but then you introduce other problems because an add won't stay in the first 2-3 pages long enough for people to browse it. Most purchases are made through browsing.
thanks
Wegs
https://www.sau.com.au/forums/topic/341192-cant-edit-posts/#findComment-3844174
We're looking at ways to revamp the for sale sections at the moment - there's a whole thread discussing it in the mod section so it's not being ignored.
I understand that not being able to edit your listings is a bit of a pain but there is method in the madness, and as alluded to previously it means that someone can't just sign up and do the dodge on someone, then remove or alter the records of what they had offered for sale.
I know it's not perfect but it's the lesser of two evils until a "proper" fix is in place. Thanks for your patience guys :laugh:
https://www.sau.com.au/forums/topic/341192-cant-edit-posts/#findComment-3845867
I think the time limit is a great idea
if people really need to edit there items for sale then...
1) pm a section moderator with proposed changes the the relevant post
2) give a donation to SAU and get the extra's that come with that
https://www.sau.com.au/forums/topic/341192-cant-edit-posts/#findComment-3846004
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
