You keep your existing turbine housing but its a new CHRA.
The compressor is different and uses a different housing to suit, yet the turbine can use the exiting 75 housings despite being different.
My take on it is you can buy both the front and rear wheels along with a compressor housing and put it all together yourself.
Righto cool, thanks for clearing that up
I could keep my turbine housing but I would need to swap out the compressor to match up with the new wheel design?
you could keep your turbine housing. You would need to swap out a "Supercore" which means everything except the turbine housing. Once you had this supercore, then you could swap back and forth turbine wheels with your existing turbo.
So the compressor housing can't be swapped because the inducer size of the wheel is bigger... Yes.??
that is correct. the compressor housing can not be swapped because the inducer size and the blade aero shape are different. Also - the bearing housing is needing to be swapped due to the 0.4mm difference in OD at the back-disc wall. For this reason, purchasing a complete turbo or a supercore would make the most sense.
The compressor is different and uses a different housing to suit, yet the turbine can use the exiting 75 housings despite being different. My take on it is you can buy both the front and rear wheels along with a compressor housing and put it all together yourself.
close... everything you said is correct except the last part
Please clear it up if you could, as my understanding was formed on your comment about put a spanner on it and thats it. As you said all parts are balanced individually
  • 3 weeks later...
Bit of a thread dig.
any word on the street about the reliability issues being resolved yet.
And Im looking at the EFR7064, but is it possible to be had in an open T4 turbine hosuing, Im looking at using a cast manifold that has an open T4 flange
like this
ufortunately there is no way of welding a divider into the collector :(
No T4 opens AFAIK Zeeb and I have been doing a little revision on these lately, but PT and Garrett would have you sorted (can get T4 open prints from GCG for the GT30-35 range).
Yes....
...but
Will it choke a 3L at 7000rpm?
Will have to attempt to find some results, but I doubt I will find anything for either the 7064 or the 5557 on anything bigger than an SR/4G/EJ etc
edit...Found a guy with twin 5557s going onto a 3.4L JZ :blink:
1 car 27 differnt plans for it lol
-5s = too much $$$ to rebuild + flucking about making oil waters lines fit :(
Im going to have to buy another Supra.....1 to put the auto + big bloody turbo in, and the other for a 5 speed and small turbo :(
anyone have a JZA70 they want to donate? haha
I am daily driving my Evo at 28psi, beating the snot out of it 4x daily. The EFR 8374 internal-WG twinscroll turbo has not skipped a beat
Also my RB26 nissan is ready to race, with EFR 8374 1.05 and external WGs i am dynoing thursday and racing saturday. 529368_10150632701911129_575236128_9575004_1038506751_n.jpg
turbokit:
wish me luck!!
Edited by Full-Race Geoff
Geoff - I thought for some reason you were going 7670 on the EVO?
What fuel, boost etc are you going to push the S14 to? Very keen to hear how that goes, good luck sir... it'd be nice to finally start hearing nothing but good results from these things.
DO show the dyno sheet please also any of the smaller EFR jobbies on a 3L (2J etc)
no problem, ill post it up. im using a stock bottom end r33 rb26 with jun oil pump and uprated rod bolts. ported head with stock size ferrea valves and tomei 280 cams, magnaflow 4" catalytic converter not gutted, Full-Race manifold recirc'd external wastegates and efr 8374, twinscroll 1.05, E85 from a local taxi station. im going to test it without catalytic converter to know the difference, its nice to not smell exhaust fumes! Also there is a 7670 1.05 on stock 2jz dyno chart ill post up
Geoff - I thought for some reason you were going 7670 on the EVO? What fuel, boost etc are you going to push the S14 to? Very keen to hear how that goes, good luck sir... it'd be nice to finally start hearing nothing but good results from these things.
i initially had a 7670 external wastegate going on my evo, but at the last minute a friend "leetevo" from evom needed it to make a race. i was able to get an 8374 internal wastegate turbo instead which worked out great because Im testing out our new internal wastegate AC compatible evo turbokit myself, daily, im stoked :) The 4G63 is a great engine.. and the car turns so quickly its remarkable, great street/track car, but to me the RB26 is something else and exhaust note is intoxicating. i find myself wanting to only build RB26s there is no other engine/driveline im as passionate about. it weighs a ton. its hard on front tires. difficult to get parts for. some people tell me the platform is weak... it cant change direction like a miata i really dont give a damn she runs hard!! super excited to be racing against a tweaked R32 gtr, apparently the guy expects to win the race this weekend.
Speaking of twin scroll EFRs on 2JZs, heres an interesting dyno comparison - twin scroll EFR8374 maxed out on E85 on a Supra, compared with a PT6266BB (single scroll) doing the same:
Tuner says intake air temps and exhaust manifold pressure were lower on the Precision turbo.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
