Firstly id like to know if anyone on SAU has gone down the twin EFR7163 path and what kind of results did they net. The turbo is rated at 550hp so would you need to run big boost to hit 1000 ?
I did have a set very early on (3yrs ago), they were prototypes so I'm not sure if the current 7163's are the same config.
Paul is correct, 20psi around 5500 and went on to make approx 600hp from memory. Didn't push them past 20psi so I have no idea where they would end up.
Roughly 1,000,000 going by Borg Warner's claims for them - they are beyond the Garrett GT3076R/HKS 3037s in flow rating, which used to be strictly "Pro GTR" type territory in the good old days of Japan drag racing. Serious serious business, so that lag isn't that surprising and realistically actually pretty impressive given what would have happened if you wound the boost up to 11. Not really ideal on a 2.6litre circuit car though!
When i started my build i had roll drags and 1/4 drag as my main priority. Ive since become more roll and top speed oriented seeing that i want to attend SM1000 next year. Ive got a 2.8 stroker with 288deg kelford cams, i think my cams might be to big for these turbos? I will be on E85, high comp and big boost. I do not want to make another mistake in my turbo choice. Its either going to be twin EFR's or a big single huffer for me.
Edited by Tyranus
Hello Guys,
Been reading this topic for a while now ... just caught up :P
Just orderd an 7670 1.05 a few minutes ago for my rb25 build (r33)
Hoping to get around the 500bhp out of this setup for a nice quick street car :)
rb26 crank
rb26 JE pistons
Eagle rods
custom manifold (2 38mm tial mvs)
delete the vct and put kelford 262 cams in there
Supertech springs
And the suporting mods for these kind of setups(fuel pump/injectors etc)
All will be at euro 98 fuel since we can get that at most places here.
  • Like 1
Hello Guys,
rb26 crank
rb26 JE pistons
Eagle rods
Supertech springs
Sounds like an awesome setup!
So you can put some super sick Kelford cams on It Paul.. Farrrrkkk don't you know anything?
Kelford are awesome, I'd put them on anything except an RB25 - nfi why they don't do a VCT cam for them... my only guess is they don't sell enough for those motors to justify the R&D :(
I need to purchase the cams so its not set yet.
Its just that I want to see something else then the std choices everybody makes.
Hope that it would not be a bad choice to delete the vct that it would realy effect the power.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
