Hi guys,
Got my car tuned the other day, it is a 26/30 and made over 450rwkw on 18psi pump through an auto. Started breathing heavily upon taking the car off the dyno I am told. It is cylinder two that is 40psi, all others are very close to 120psi. Put some oil in the bore and it went up to 65psi. It has argo rods and cp pistons and rings.
1) what is the problem? Rings gone bye bye?
2) Why did this happen?
3) Is this common or something to expect?
4) how much to fix if engine is taken to engine builder?
Thanks in advance
Hi guys,
Thanks in advance
id say it could be a number of thngs. it could simply be the head gasket has cracked around that cylinder or your rings have gone bye bye or many other things. i would say if its rings its a ring change depending on the bore itself. correct me if im wrong guys
if it's your rings the I've been told the comp would come back up more than that, almost back to normal. Leak down test time for diagnoses.
Yep - to elaborate, the oil makes up the piston to cylinder clearance, like a ring would, so;
- if the compression comes back, your rings are stuffed and top end is good
- if it doesn't come back its top end, ie valve/head gasket/cracked head... OR both top end and rings....
Hi guys,
Thanks in advance
Had the same thing happen on my rb26, number 2 had about 25 psi, and the rest around 130 psi. Have stripped the motor down to find that number 2 piston was melted around the ring land area :P
^ hope you use another tuner once its rebuilt.
rarely hear of a single piston melting on a proper tune.
Hadnt had a tune, stock engine stock turbos stock ecu, but with an injector with alot of crap in it. *sigh*
there is your problem, one lean injector probably = a hole in your piston if comp is that bad with oil in it. A decent tuner should have picked up the detonation though and needing more fuel than normal to compensate for 1 cylinder barely firing.
I'd be asking them what knock detection equipment they use and if they say none you ask for nothing less than a refund.
Edited by Rolls
haha i know that was my problem, thats why it only leaned out on 1 cylinder. As for the tune as stated before it never had one, so i only have myself to blame for it :P
oh right I got the impression it happened on the dyno, you said it happened after tuning, so it was happening before you took it there, why would you get it tuned if it was pushing loads of oil into the catch can?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
