Just completed fitting the rb26 inlet manifold to our rb20det
The process was simple
Took just over 1 weekend to complete
*Cut rb20det runners
*Cut flanges off of rb26 manifold
*Aluminum weld them
*Weld aluminum flange to mount throttle body to the front of the plenum
*Cut and re-position water inlet
*Use porting tool to grind all uneven levels in welded runners (allot of porting is needed)
*Install throttle body
*Install stock rb26 aac valve setup
*Install manifold
*install fuel system
*Run new vacuum lines
*Rerun new intercooler piping
*Relocate bov
....thats about it
People said that i would of lost power
but all we got was good results :P
*The boost is building quicker
*The acceleration is way better now
*The throttle response is really great
*Less intercooler piping (about 4 feet or so less)
and no need to weld a flange to mount the aac valve, we used the stock rb26aac valave setup
* i really cant complaim about anything its a really great upgrade*
more pics will be posted soon
Someone asked me what was my supporting mods
its as follows
*Stock rb20 motor
*300zx 45v3 t3 turbo
*10-12 psi boost
*TurboXS boost controller
*Blitz bov
*Blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*Gear box rebuilt
*Upgraded ecu ( flashed\remapped )
*Fidanza 4.3 ceramic clutch kit
*NGK iridium spark plugs
*Walbro external fuel pump
*Runnin on castrol syntec
It will never work. Opps it does damn it .
Ha ha I always wonder why people pull the rb26 intake off and go to a single throttle body
You have done it the oppisite way and made more power good on you.
Would have been great to see an in gear rolling start 40-60km/h, 40-80km/h, 40-100km/h times and a dyno. Did you get the ecu re-flashed? If not then can there really be that much of a difference if the things airflow characteristics didnt change enough to require a tune....or if it did....do you know what is different about the tune in the way fo fuelling and ignition?
Surprised its made such an obvious difference with the turbo and power you are running because there have been various posts with some positive and some negative...lol woudl love to get my head around the reasons :P
But good work on getting it all together and running to your satisfaction
Edited by Roy
one you drive yout car every day and you do an upgrade you will fill the difference be it good or bad
The placebo effect can be very strong when you have put a lot of time and effort into a mod though.
Dyno is hard evidence, shame would have loved to have seen a before and after
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the AAC/IAC chamber .
How ever you got it to work - well done .
A .
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the .
A .
it was really easy
The 2 lines that run from the two steel tubes decending between the two RB26 runners to the AAC/IAC chamber are vacuum lines
so what i did was run the lines from the 2 metal hose fittings under the RB26 plenum to the AAC/IAC chamber
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
