Just completed fitting the rb26 inlet manifold to our rb20det
The process was simple
Took just over 1 weekend to complete
*Cut rb20det runners
*Cut flanges off of rb26 manifold
*Aluminum weld them
*Weld aluminum flange to mount throttle body to the front of the plenum
*Cut and re-position water inlet
*Use porting tool to grind all uneven levels in welded runners (allot of porting is needed)
*Install throttle body
*Install stock rb26 aac valve setup
*Install manifold
*install fuel system
*Run new vacuum lines
*Rerun new intercooler piping
*Relocate bov
....thats about it
People said that i would of lost power
but all we got was good results :P
*The boost is building quicker
*The acceleration is way better now
*The throttle response is really great
*Less intercooler piping (about 4 feet or so less)
and no need to weld a flange to mount the aac valve, we used the stock rb26aac valave setup
* i really cant complaim about anything its a really great upgrade*
more pics will be posted soon
Someone asked me what was my supporting mods
its as follows
*Stock rb20 motor
*300zx 45v3 t3 turbo
*10-12 psi boost
*TurboXS boost controller
*Blitz bov
*Blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*Gear box rebuilt
*Upgraded ecu ( flashed\remapped )
*Fidanza 4.3 ceramic clutch kit
*NGK iridium spark plugs
*Walbro external fuel pump
*Runnin on castrol syntec
It will never work. Opps it does damn it .
Ha ha I always wonder why people pull the rb26 intake off and go to a single throttle body
You have done it the oppisite way and made more power good on you.
Would have been great to see an in gear rolling start 40-60km/h, 40-80km/h, 40-100km/h times and a dyno. Did you get the ecu re-flashed? If not then can there really be that much of a difference if the things airflow characteristics didnt change enough to require a tune....or if it did....do you know what is different about the tune in the way fo fuelling and ignition?
Surprised its made such an obvious difference with the turbo and power you are running because there have been various posts with some positive and some negative...lol woudl love to get my head around the reasons :P
But good work on getting it all together and running to your satisfaction
Edited by Roy
one you drive yout car every day and you do an upgrade you will fill the difference be it good or bad
The placebo effect can be very strong when you have put a lot of time and effort into a mod though.
Dyno is hard evidence, shame would have loved to have seen a before and after
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the AAC/IAC chamber .
How ever you got it to work - well done .
A .
I'm curious to know how you got the IAC/AAC system to work considering the log sits on top of the RB26's inner manifold section and has two steel tubes decending between two of the runners and connectiong up to the .
A .
it was really easy
The 2 lines that run from the two steel tubes decending between the two RB26 runners to the AAC/IAC chamber are vacuum lines
so what i did was run the lines from the 2 metal hose fittings under the RB26 plenum to the AAC/IAC chamber
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
