  • Replies 62
Yeah I have them and whilst they are reasonably long lasting with decent dry grip for a street tyre, they do have some road noise and suck in the wet if you don't baby it. Access were the cheapest at the time of my purchase. Gonna try Kumhos next time...
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5521075
i know ku36s aint great either then again, rwd + turbo. what ya expect.
anyone tried the federal evos? willing to spend that bit extra for half decent wet weather tyres.
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5521359
Go and see Trackside tyres, Kilsyth, he has the latest Federal Semi out at the moment Z XXXX (XX= something something) :P
They ain't even listed on their website yet :(
Saw them there today and nearly became a guinea pig :D
option1 have been selling them for a while. so a few of the guys up there are running them. or is
there a newer version of these? they do a soft, medium, hard compound I think.
http://www.federaltire.com/en/html/pdetail...ine=5&ID=44
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5521392
Why the need for wet weather grip?
Realistically, you spend maybe a dozen days a year driving in the wet. The other 300 days it's dry. So long as you are careful, a "good" wet tyre vs a "bad" wet tyre isn't going to matter a pinch of shizen. It's not likely that the "good" tyre will ever save you from a sticky situation, so why aim for that? You're more likely to stack when having a fang in the dry.
Get a tyre which best suits the 99% of driving you actually do.
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5521424
Whilst I agree with your perspective it depends on the how often you drive the car and how bad the wet weather performance is.
For my daily driver I chose tyres which offered exceptional all round performance, drive brilliantly and cost a fortune (Michelins). I don't use these tyres on my weekend car which I tend to drive the car roughly 1-2 times per month were I use KU36's.
Whilst the KU36's are ok and they are exactly what I expected (great dry grip, slightly stiffer side walls with a little higher NVH) in every way except wet performance. There wet performance is below what I would have expected with little to no feedback and being highly unpredictable.
For someone who drives there car daily I would suggest not using KU36's.
Here is a review which I agree with, particularly in terms of the vauge feedback and how the car suddenly and unexpectedly looses traction.
http://www.caranddriver.com/reviews/compar...omparison_tests
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5521444
But as Peter said, wet + turbo can make any tyre look crap. Wet weather performance is 99% how you drive rather than they tyre holding your rims off the ground.
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5521448
Not true at all. Whilst driver skill always has an effect the difference between good tyres and bad tyres and how well the tyre provides feedback to the driver is paramount to car control.
Tyres are the point of contact between the car and the ground they are the most important factor in car handling, grip and performance for both wet and dry conditions not just holding your rims off the ground or how much throttle you can use on boost whilst going through a puddel.
Tyres are often understated and in particular the value of what a great set of tyres are worth well after the purchase price is forgotten.
https://www.sau.com.au/forums/topic/342179-federals/#findComment-5522006
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
