I did give the tuner a manual turbotech boost control bleed valve, and he tried that and it made boost control worse...
I'll play with wastegate preload and boost control gain on the PFC and see what happens....
  • Replies 182
Boost control as others have mentioned is shocking...
Ditch the Power FC boost control kit as it is junk, either install a Turbotech bleed valve for $35 which will work very well or fork out for a Blitz Dual solenoid (spec r or IDIII) so you can have multiple boost settings
I think shocking is a slight exaggeration. Yes it could be improved but take a look at joeyjoeys boost curve with the same turbo, it hits boost faster but still drops off about 2psi. It could be the turbo and engine combination that means it cant hold 20psi till redline. Turbos that have a strong midrange can often do this. A lot of the 3076s and hypergear turbos seem to exhibit this behaviour. I think someone said its to do with the amount of air flowing through the wastegate pushing the wastegate open (overcoming the actuator spring). In this case I dont think a boost controller can help you.
But by all means I would be winding the gain up to get it as close to joeyjoeys result as possible.
Interesting, I could understand that it did not improve the boost control as the wastegate was overcoming the actuator spring but I cant understand how it could make the boost control worse?? I dont think it was setup correctly.
The main issue with Turbotech (a few years ago) that I have seen is that as boost rises small turns can lead to large increases in boost.
For low levels of boost they seemed to be great value but closer to 18psi it was getting a bit erratic so perhaps the tuner had a similar issue??
needs a stronger actuator. I would go for a 24psi atmospheric pressure rated actuator, whichs should hold 18psi without boost controller. Garrett part: 446131-23
I'm running the std HKS actuator and the PowerFC boost control kit...
people say the same bad things about Vi-pec boost control, its just a DC adjustment and when setup correctly will nearly as good as any
I'll share a little recent/ongoing boost control experience with GT3037 Pro S on 30DET.
Started with 12psi actuator running straight feed to the actuator, no BC. Definite problem with boost slowly building then running away to 19psi and tapering to 16psi; not readily fixed or changed with preload.
Changed to a 18psi actuator, trialed with straight feed again. Slower boost build to peak 19psi, again tapering to 16psi. Obvious that actuator spring strength affected the rate of build, and was generally more effective.
Activated and tuned the Vipec BC map. Found that it is very sensitive to adjustments, and duty cycles were effectively addressing the characteristics observed when not running any BC. ie. high DC to promote fast boost rise, quickly tapering to allow the actuator to do its thing and limit boost to the observed peak. Then finally start to ramp DC back up so that boost didn't fall again beyond 6000rpm. And come to the conclusion that the turbine is probably getting to its flow capacity and starting to struggle a bit.
I did find that the boost "curve" was a bit wavy and didn't look super smooth with up to 1.25psi variation through the range. Not my ideal but it works ok.
Comment to OP: make sure you use an actuator not far removed from your target boost. Light-pressure actuator probably won't cut it if you want to run some bigger boost levels. Get the preload set right. An extra turn or two on the rod will make a difference. Be prepared to play with EBC settings to get it "right" or at least to an acceptable degree of control.
Good luck and don't worry too much about the power number. Look at the shape of your torque curve.
thanks for the comments Dale, I'll play with some small changes and if they dont get me the on boost response Im wanting I'll look at another actuator...
Its all about response for me, top end power is good, but response is better...
This will feel like an absolute weapon on the street I'm sure, more so once your boost issue is sorted. Congrats mate, I think you have helped me make up my mind on this turbo, to my laymans eyes looks much better than what the 3071 would deliver.
Did you get the whole pro s kit or just the turbo?
Sorry for the little hijack:)
I was able to find the turbo brand new with gaskets and studs for sale heaps cheap (like cheaper than a 3071 would be) in the for sale section...
Hopefully I can get it to achieve full boost by 3500rpm and bring the whole curve on earlier... maybe play with the VVT as well..
Can I note, you are making power in the following intervals:
3-3200 100kw~
4000 200kw~
46-5200 240kw~
6-7300 280+
Now may I ask, where would you like to IMPROVE YOUR RESPONSE?
Response is how quickly the car makes power, not how quickly it comes on boost. Torque wins races, certainly not PSI@xRPM. While boost response may be a set variable to how a setup may perform, it is not the key indicator.
Consider when plotting the compressor map of a turbo, variables taken into consideration is RPM/boost/engine VE/engine size. Alter the engine VE and for the same flow you will be pushing LESS boost than before. Same FLOW = same POWER.
You are achieving a result that some argue is not possible from a turbo this size, are you certain that you need your boost to come on earlier? And are you certain that having it come on sooner will not make for a less desirable outcome overall?
I remember I had an evo 4 with the most epic response id ever seen, truth of the matter was it would hit target boost at something along the lines of 5000RPM on the stock turbo. Infact I found that fairly normal for an evo with my mods. Friends had similar cars with more restrictive exhausts and saw boost on notably earlier, but also were NOT as fast when it came to torque or response.
Key point, I believe this turbo wishes to run at roughly 18 psi on this motor - not more. You are also achieving this by 4000RPM, for a 6 cylinder this to me sounds like epic delivery.
How does the car actually Drive now? Please elaborate.
well I must admit Im yet to drive it in the dry, so I couldnt actually get past 4500rpm today... (maybe that is saying something) but as soon as its dry I'll take on a favourite road and see what happens...
I guess it'll become a traction game eventually...
I want instant power basically, so I can control the car with my foot, not just foot down waiting for power to hit...
With better boost control there is more to be had earlier on the ramp up to 3600rpm. It is making the numbers otherwise.
Does it matter? This is a SAU so squeaking out every last bit of performance (especially early/midrange) is serious business especially when someone else is paying the bills.
LOL, it doesnt matter no.. I just am not confident it has much more to give.
I base a great deal on feel when driving, one of these is RPM points of a motor. While a good 2L4 has something to show for 3500RPM, those are not necessarily big revs for a I6. I would say I am of the opinion that a 6 makes peak torque on a good street setup roughly 1000RPM later in the rev range than a 4 (say SR20 or 4G63 vs RB). This doesnt translate to lag in my opinion, I think these are simply the delivery characteristics of the motor.
Personally results in question only further concrete the fact that I WANT one of those turbos. :)
3076's do not have that issue at all. They will smash 20-25psi @ 8,000rpm no problem.
My GT3040 had 24psi until 8,000rpm without a sign of abating. It was external gate (.82), but a proper IW housing on the 3076 and you wont have these problems.
Its just a case of the compressor nosing over really IMO.
The next step is the 3037ProS in the HKS speak which is virtually the same as the 3076 and they never had any issues either and would make 300-330rwkw on PULP on a 2.5ltr.
Dale's example is a bit of a odd one, i wouldn't have thought it would drop that hard at all as the rear certainly isnt running out as they are a .78 IIRC either way they aint running out of exhaust flow.
Can you check your EX cam gear setting?
totally forgot man.... i'm running a greddy ex cam gear aswell
Its the same format as joeyjoeys dyno so 'Dyno Dynamics'
one is DD the other (finished is a dynapack, set to give the same results as DD)
we played with my setup HEAPS (well in excess of 100 passes) and found that it likes as much gain as possible to spike to between 20 and 21 psi to get things moving, and then to hold as close to 18psi as possible.
there is definately room for a little more fun in that setup.... but not that much more... at this point my number 1 concern would be safety
Well now you can sell it to me for my JZ lol
I had the 3037 pro S on my RB25 for a very short stint at 10psi. It felt like it would have been epic, although there is something that the back cut wheel and 71mm compressor just do in my pants.. Cannot deny!
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
