Bought and installed a new battery today (with larger terminals to suit, and a new battery clamp to hold it in). I now have 610CCA's of juice available to kick my starter motor in the guts!
what shade did you go on the window tint josh? darkest legal? just wondering how it looks against the stock rears shading.
we went with the darkest legal shade which here is 35%- I like having a car that doesn't get picked on by the cops (yet). It looks pretty good. You can tell it's lighter but there's not a huge difference. But then that could also be due to the front windscreen being so light? I'll try to get a decent pic of it.
(sorry for butting in :blush:)
Edited by Cheddar
I used those TRW Lucas pads in R32 GTR calipers on my R31, very nice, from stone cold to the hardest I could push 'em.
Get used to washing those wheels; they're dusty buggers...
:blush: some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
i'll probably swap them out for the qfm hpx when i've got the money or am sick of washing the wheels
;) some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
Get a can of Autoglym wheel seal for your rims, then you'll basically be able to hose the dust off.
(sorry for butting in :D)
lol jo. it is your car after all :) i'll keep an eye out for the pic.
On the weekend I finally go around to fitting the carpc into the wagoon, had already fitted teh screen previously when I put the CB in but had a couple of wiring issues.. got those sorted out yesterday so now everything works mint!
Must say, I've missed having a carpc!
Oooh, post photos when you're done, please!
Last night finished fitting new tie rod ends to the Stagea. This morning had a full wheel alignment done. :P
Saturday the Stag gets a brake upgrade ... Sumitomo 4 pot calipers and 297mm rotors ... Lucas pads :)
put in my tranny cooler, hard suction line to turbo, turbosmart BOV (couldnt be bothered with having to plumb back the standard BOV) and also dropped the front drive shaft,
definatly fun times being RWD but pretty just doing it to make it easier for when i get it tuned soon,
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
