Bought and installed a new battery today (with larger terminals to suit, and a new battery clamp to hold it in). I now have 610CCA's of juice available to kick my starter motor in the guts!
what shade did you go on the window tint josh? darkest legal? just wondering how it looks against the stock rears shading.
we went with the darkest legal shade which here is 35%- I like having a car that doesn't get picked on by the cops (yet). It looks pretty good. You can tell it's lighter but there's not a huge difference. But then that could also be due to the front windscreen being so light? I'll try to get a decent pic of it.
(sorry for butting in :blush:)
Edited by Cheddar
I used those TRW Lucas pads in R32 GTR calipers on my R31, very nice, from stone cold to the hardest I could push 'em.
Get used to washing those wheels; they're dusty buggers...
:blush: some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
i'll probably swap them out for the qfm hpx when i've got the money or am sick of washing the wheels
;) some ppl were saying that they aren't too bad but i've noticed a fair bit of grime already
Get a can of Autoglym wheel seal for your rims, then you'll basically be able to hose the dust off.
(sorry for butting in :D)
lol jo. it is your car after all :) i'll keep an eye out for the pic.
On the weekend I finally go around to fitting the carpc into the wagoon, had already fitted teh screen previously when I put the CB in but had a couple of wiring issues.. got those sorted out yesterday so now everything works mint!
Must say, I've missed having a carpc!
Oooh, post photos when you're done, please!
Last night finished fitting new tie rod ends to the Stagea. This morning had a full wheel alignment done. :P
Saturday the Stag gets a brake upgrade ... Sumitomo 4 pot calipers and 297mm rotors ... Lucas pads :)
put in my tranny cooler, hard suction line to turbo, turbosmart BOV (couldnt be bothered with having to plumb back the standard BOV) and also dropped the front drive shaft,
definatly fun times being RWD but pretty just doing it to make it easier for when i get it tuned soon,
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
