just got an oval Varex muffler fitted. 3" turbo back with cannon was just too loud for my GF and nieghbours, but I didn't wanna sacrfice too much flow with mid mufflers etc. Sounds great wide open, it's a bit quieter than the old cannon too. And closed its like :P
you will want to start the next day they need a bit more go in them..this is what i have
turbo tech boost controller $30.00
exhaust i recommend hks silent good sound
nisstune $800.00 +9.psi boost will go to 11 soon
164 rwkw
next is return flow intercooler and 1 day high flow the turbo
i wasnt planning on boosting the car
lets be honest its a station wagon, im not tryin to run times here lol
mine has a nur catback zaust. ill make the rest up for it soon.
i wasnt aware you could get nisstune for vq25det
That attitude won't last long.
A station wagon that eats most things for breakfast? it's fun and different :banana:
And the hillarities that ensue when I put it in 2WD make me happy in my pants.. lunchbox sideways down the street? Priceless!
It's actually more amusing than my 32* :P
*Until the 32 has 500rwhp with gate.. then that will be more amusing :P
Edited by bubba
didnt know you were getting am m35 stagea thought it was a c34
put in a set of BC coilovers, the BR model....needs a little bit of adjustment hight wise,
might bring the back up slightly or drop the front a little more....
Before....
After....
Pretty happy with it overall....
Before....
After....
Looks like crap...
:D
From here looks like your running some SERIOUS negative camber on the rear or is that just the pics?
Go the BC's, great value for money, you won't be disappointed.
Took mine out for a run around a private track while on a job yesterday... A heap of fun! Couldn't keep up with the 911 turbo or R8 but I had a blast!
How were your brakes and transmission after a few laps?
which track?
Before....
After....
Looks good
which track?
Transmission was fine, brakes were dead after 2 laps... I'm not too sure what pads are in there, but once I have done cooler/exhaust I will throw some 350Z Brembo's in.
yeh heaps happy with them, know a few people who have them now and no complaints so far...
Mine have been in since Christmas, perfect, better than the price suggests. Once you've set your final height, get a good 4 wheel alignment, it'll really finish it off, & your tyres will thank you!
V35 rims go in today for new shiny paint! Just have to pick the colour, not going shadow chrome, paint alone cost $250 a litre! Also on the downside, my wheel painters prices have gone up by quite a lot, yikes!
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
