haha im not going to install till the brake rotors arrive, then ill do brakes and suspension at once to save wheel removal time
i wish i could have done it tonight, had photo comp to go to instead
Let me know if you want some measurements for setup, might save you some time :) .
what rotors you getting dude :?
*peaks interest*
dunno wtf duncan came from.. dyslexic with peoples names lately.. dale! lol :rofl2:
All good :) , don't you like my name? Last time it was "Greenieo" Lol!
Edited by Daleo
:) Well I guess there are two Duncans in the Stagea forum.. Spose we just end up on peoples mind :)
ohh yes please! im going to set the height before i install them so i dont have to do it again.
also found out the spring rates, they are on the box. F 10kg / R 12kg
*peaks interest*
just slotted RDAs mate, nothing special!
Pm sent.
Managed to pickup an Informeter Touch on the cheap from the States, unfortunately the seller only offered shipping within the USA - so Im proxy'ing it through 'ShipItTo'. Its arrived at one of ShipItTo's warehouses, so hopefully they'll send it out Friday their time (our overnight), and I'll get it Monday/Tuesday :P
Edited by Dunc
Nice one! Those parcel forwarding services are great!
I just received my Nismo stuff. VERY excited!!
Yeah I did some research before I decided to jump on to one, been pretty happy with the service so far. Its not exactly 'cheap' but it still works out cheaper than I can git one elsewhere; I guess they do have overheads & want to make a profit. Cant hate on them for that :P
Awesome stuff re: Nismo! You're all stocked up now! Have you ever done a power run on the dyno? Would be a nice 'look what I did in a weekend' power change :devil:
cracking it open to have a look before you put it in or what? :P
Edited by Jetwreck
Awesome stuff re: Nismo! You're all stocked up now! Have you ever done a power run on the dyno? Would be a nice 'look what I did in a weekend' power change :)
you pay for the service! if it works for you, then it doesnt matter :)
cracking it open to have a look before you put it in or what? :devil:
sure will, ill take heaps of pics before i install it at 5pm :D
sure will, ill take heaps of pics before i install it at 5pm ;)
Good man! Will be interesting to see if theyve done the same thing as Impul on the main chip (in terms of covering it in gunk so it cant be easily re-read)
weird, its EXACTLY the same inside as the stock one. no mods appar visible..............
Basically confirms that its just a re-flash, not any sort of internal piggybacking etc. Good news of that being that if we ever have someone who can work on them locally they'd be able to read the Nismo ECU to get a starting point for tuning ;)
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
