thanks for your kind words pete :P
Oath. That seriously is nothing. They aren't even bent!
Any wheel repair shop half their worth can fix that easy, and it wouldn't be that expensive either which is good.
I've seen heaps worse than that!
easily fixed dude. dont stress :P
thanks guys .. you put me at ease :P
Loaded my ARX onto a truck to go back back to Sydney for warranty repairs. Ahh living in the country fresh air, the mountain views and no bastard has the slightest idea what is what if it is if not a smelly falcodore!
:P
Now waiting to see how many scractches and chips the spotless paint gets in transit. :O (Still)
picked up a 1250kg aluminium jack for $100 (rrp $400)
the joys of having mates at supercheap
i got a 2500kg one for 100 today.......... form sca too
i got a similar thing this week, but it's 4000kg and cost me $3500 :P
Edited by Big Fella
i got a similar thing this week, but it's 4000kg and cost me $3500 :O
hahahaha show off :P
i got my gizzmo kmon in the mail this week. i'll be hooking it up and having a play next week sometime.
Edited by QWK32
Nice.. what's the torry got in it? :P
that torrie is the spare car, it runs a big port 253, trimatic and straigh out pipes, throwing it together to attck some hill climb events next year for fun. we bought it as a parts car for the wifes Lh 4 dr. and then scored the driveline for free so i've painted it and i'm in the process of putting a cage in it.
the other torrie is a SLR mock up, 308, 288 cam, vn heads and rods, flat tops, turbo 350 trans, 9 inch rear end, 330mm front discs with 4 piston calipers. that one is currently at the chassis shop getting seam welded from fron to rear.
now you see why i need a hoist!
mine is the aluminium "race" jack, should have been $200 cos its reduced to clear (don't sell enough of them)
just adjusted my handbrake on each hub and put some stop squeak on the back of the pads while i was there
i adjusted the handbrake from memory, is it tight till the rotor wont move then back off 6 clicks?
also
if anyone wants a specific page of the workshop manual with the characters recognized just pm me and i'll send you them
i left my computer slaving away for a few days and i think it converted most of the images into a searchable document :)
so now it can be translated into ingrish by google translate
finished cleaning the stagea in preperation for the adelaide stagea cruise in the morning. luckily it's forecast for rain(cause i did a pretty half arsed job of drying the car)
Edited by Big Fella
Have you put the swaybars on?! should have been the first job for the new hoist! :)
nope. got called in to work early on friday and then had to fit my new whitewalls to my dodge this arvo, it was on the hoist already.
and then i got lazy and fell asleep on the couch.
They'll probably get fitted in between getting my towabar fitted monday morning and and going to metallica monday night. hopefully!
Retrofitted m35 stagea arx turbo actuator on hks gtrs turbo on the r33 - andys turbo saved the day.
found boost cut solonoid and disconnected it and now running proper ramping and auto duty cycling from the gizzmo without creep or boost drop off between gear changes.
retarded timing via cam angle sensor.
took off entire cooler and piping and front bumper inspected piping replaced silicon reducer to cooler that was split. gave cooler water test for leaks.. all good.
modified the plastic rubber intake pipe as it was squeezing in on itself under high boost to turbo with a stainless pipe. - because of this stock bov had to go ..and was blocked off for the time being to keep idle - with a plumbing one way valve- lawl. yes theres flutter.
Put in new ngk 7res plugs as previous owner had 6res in there and it was jumping spark to the side of plugs ..they were black as. (confirmed it had the blue spitfires in there .. he wasnt lying :)
Put in 4 litres of royal purple 5-40watt oil.
Degreased the entire engine bay.
Swapped out the 18's for 17' stagea m35 rims.. (18s tyres were like dragway slicks and total cop bait)
Ripped off rhs front panel that was dented and replaced with spare black gt panel.
Replaced dented mud gaurds on rhs.
wheel alignment monday and camber reset ..i dare say its out heaps as the hicas is going spazzo
pics to come.
mods to come -coil overs (the first thing - anyone know good sources?) ,sard fpr, sway bars , new front bushers , nismo lsd diff
proper plenum , z32 afm and 650cc injectors , , power fc is sitting on the garage floor (with tune) - new bonnet .. this one is mad dented
car was purchased 3 days ago and wouldnt even do a skid.. now kicks at 80!
Edited by PetroDola
Not today, but pulled intake plenum and stack off and clean out with brake clean/petrol. Sludge free!
Replaced ribbed intake rubber with silicon joiner.
Next mission, catch can so oil blow by doesn't go back into intake.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
