custom sub box fits 2 X 12 inches in between the strut towers very snugly
amp goes in spare tyre hole, its a big amp :P
oh sweet did you get it made for you?? cost much? i'm looking to get one made to fit snugly behind the seats between the struts aswell!
as my currently enclosure I bought doesnt fit properly :(
haha and who needs a spare tyre when u got BASSSSsss :)
Brett @ Performance Car audio:
http://www.performancecaraudio.com.au/
If we have a stagea meet your more than welcome to measure up my setup if you want, it shouldnt be too hard to make, just made out of some MDF i assume :P
and yep no need for a spare wheel when you have bass, that and it would f**k up my 4wd system if i ever put it on :P
hahah I call my spare wheel "teh cheese cutter"
oh stag meet i'm in on that :D (DAMN SHE'S DIRTY ATM)
haha last one I was in studio.. but that's all pretty much done now... just a few more sessions!
what i'm thinking is reboxxing my 10" type R Alpine into a enclosure that fits in there nicely, but leaves me all the room i already have for my band gear... then mounting an amp on the side of it!.. :)
nope
just need to make sure you stop in on the forums so you know when its on :)
...and make sure you don't act like an attention-grabbing idiot while out on the road. SAU has a pretty good reputation across the country, we don't need people ruining that.
:D
:D
+1
hey guys,
i'm pretty sure i've got a slight leak from the round black oil reservior on the right of my engine..
it has been fine after i got it serviced but its doing this grinding whining noise coming from my power steering again haha :(
what sort of oil do i need to put into it ?? :) just gonna keep topping it up til i get it fixed!
Tomas
hey guys,
Tomas
ok it should be Dextron 3 :) couldn't find the info on here for some odd reason whistling.gif probably cos i'm a n00bdomokun.gif
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
