no need to alter the cruise route, Dunc probably isn't coming anyway :nyaanyaa:
but seriously tho, we all know that on the cruises we must always abide the law, no excessive speed or noise and certainly no street racing(unless on private roads :thumbsup: )
*cough* :ph34r:
yeah thats what I meant, I know a guy who knows a guy that has a second cousin whos dad has some land and his drive way, man you should see it!......
.....going back to my hole now :domokun:
but seriously I was joking, sau has a good name that I don't want to be responsible for ruining
*cough* :ph34r:
thats all right i know big fella knows a couple of quite private roads :thumbsup: seem to remember somthing :whistling: i suppose all spots filled for dyno day now ? should hopefully have mine sorted this tuesday or wed after changing a few things.
How bout that local terrorist asshole?
Mumduh Habib obviously wants to get killed or deported, saying there was no evidence bin Laden was a terrorist...
Video taping yourself claiming responsibility for orchestrating people flying into two skyscapers isnt evidence? I dunno what the 'right' thing to do about him is; but can you imagine if he lived in the States and tried to sprout that shit?
the KKK would be after him.
And the rest.
If there really was no evidence, he's pretty f*ckin stupid for putting out videos accepting responsibility for attacks... Habib was in Gitmo though, saying stuff like that makes you wonder why he got out...
Funny thing is that the Sera can be had for under $4k, has a fuel efficient 1.5L and is very different to most other cars.
They don't look too bad in stock trim if you like the rounded 90's styling (plus they have gullwing doors :P)
Here are some for sale
http://www.carsales.com.au/used/toyota/sera/
