My main complaint with the Evo was that in some ways its too easy to drive. Very clinical, razor sharp but a little soulless. A very fast car and I miss it heaps but I like something that can bite back a bit.
someone edited their post lol
i didnt? :unsure:
you shouldve traded me then. wouldve had a powerful stagea in your hands now!
As would I... depending on cargo space.
How would your Ridgeback go in a "small" wagon?
I know my two dogs would probably get quite car sick due to lack of space if I was in a smaller wagon/soft roader
Back on topic... not that there is one in here.
I would drop my Stagea, and get one of these in a heartbeat if they were available in Aust.
Evo Wagon
if our car came in sedan or coupe form, id be getting that
Not great in a Lancer, I think they are quite small cargo wise, but they still have that boxy shape, which allows dogs to stand up. Thats not really possible in a Holden sportwagon/mazda 6 wagon.
Two Dogs would be a no no I think, unless they were smaller dogs.
But heck- Evo wagon- that'd be almost more of a sleeper car that what we have!:banana:
Alex, I've seen (and photographed) an Evo wagon here in Sydney a few weeks ago, link: http://www.autocult.net and follow the link to the JDMST meet.
I think I rememeber reading a little while ago that they (evo wagons) could only be brought in as personal imports
Wow Nick, very interesting! I was under the impression nobody did the complience work on them. If there is just one floating around, maybe its a persoanl import...
Anyway... one car is in the country, thats a better probability than nil cars!:thumbsup:
oh...
http://forum.jdmstyl...ts-Introduction
well, a bit lol... be am importer of JDM cars, and drive something none of your clients can get! I guess you stay unique that way!
Edited by PN-Mad
I like to think I'm not a completely naive retard, but can someone tell me how the fk something made in Australia is SUBSTANTIALLY cheaper in the US?
I'm looking at brake discs, and I've decided I'd prefer the DBA 4000 slotteds, but they're pretty epically expensive compared to the DBA street series and the RDA ones. And by epically expensive I mean almost twice the price.
Checking on ebay, as I usually do, I found I could get the DBA 4000 rotors for a 350Z touring from the US for almost half the price of Australia.
Unlike the street series and RDA, the 4000s are made in Australia. By an Australian company. So how on earth can they be cheaper form the states? :wacko:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
