I wouldnt worry about that. Some mates were trying to convince me I didnt need a 70-200 2.8 IS, so leant me a non IS. Brilliant bit of glass. My next purchase for sure.
Seen those, look nice. Although considering how small and light it is Id ditch the lenses and get a nice flexible zoom lens.
Youre a sick man Craig... Go talk to your wife then!
fkn lol ryan you havnt been around long enough me thinks hahahahah
Yeah, I'm getting by without the IS - the only shaky shots I've shot so far were indoors at a Uni graduation where I didn't think it would be curteous to use a flash and I was a long way away at the back of the hall, and there were too many people around to set up a tripod.
nick you should get the 70-200 F4, its lighter, and smaller too.
Nah, I'm liking this lens more and more as I use it, and I like the extra stop of light, as well as the DoF. Can't afford another lens for a while, anyway. I'm just going to put up with the weight.
whats that LOL and how does it differ ?
you wouldnt be using it at such a large aperture anyway?
i run mine around F7.1 anyway. so wouldnt matter anyway.
Yeah, but sometimes I like to shoot wide open. And it's about options - it's always good to have options, right?
To be fair, chances are your flash wouldnt have been able to throw sufficient light to assist you here any how :P
Maxed out your usable ISO range already? Very much a rock and a hard place situation if you had :(
Yeah, no doubt.
Yep, ISO was maxed out, I should see how much I can recover it - it was mega-grainy.
just use a noise reduction program. sometimes they work well. i guess it comes down to how noisy your camera is at whatever ISO youre using.
get a 580ex speedlite, its got 200mm zoom (i think)
Ive seen Noise Ninja do some fairly amazing things. Smart software.
If Nick has a crop body & his lens was at 200mm then even the 580 wouldnt help - as he'd technically be at 320mm. Ive never shot with a monopod, but under those sort of circumstances it might work well..?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
