Ever come across some car on the net that made you uncontrollably giggle like a little school girl...?
I had that experience tonight at work. Was surfing along, quiet as at work... then BAM!w00t.gif
Rocky Auto S30 with dry carbon panels, a RB30D (yep, 3 litre, with a RB26 head, and 3 duel throat CARBS!)
Now, I've seen Rocky auto stuff featured before, but it hasn't done much for me in the past. Anyways, the car is currently FOR SALE for about 13 million JPY. So if any of you buggers picked up the new years lottery... buy this...NOW!thumbsup.gif
http://www.modified....-z/viewall.html
Edited by PN-Mad
I mean, having to wait for one or two sets of lights.
Blows my commute out from 40 mins to 50 mins. Total bollocks.
Thats completely unreasonable. Id be writing letters if I were you.
Rush hour in Adelaide...
1000km run-in service & dynotune on Friday.
Forged bottom end, ported head with Tomei cams, gt3076 highflow, S15 450cc injectors, chipped ecu + tuneable piggyback ---- what boost should I have it tuned to?
I believe the ATS Gt3076iw BB turbo losses efficiency around 21psi.
I'm thinking 18psi should be fine, allowing spikes to 20psi (if that happens).
Don't want to stress the engine tooooo much; might just settle for between 1.25-1.33bar I guess.
Ideally the tuner will just keep ramping it up until there is no return for the extra boost and then set it at the figure thats still giving benefit. Hope you get to keep the car although to be honest they are not cheap to run - I am spending $100 - $120 a week on petrol alone!
True. To keep costs down im thinking tho im best to say X-psi tune thanks. Yeh stuff it, I'll tell them tune between 1.25 & 1.3bar thanks very much, and go from there.
Most likely keeping it, biggest (only) worry is "suspicion of defect" by an over zealous Officer in which case id be reamed big time as I have stuff all stock parts & can't deal with the hassle of inspections while at Uni, associated costs, etc. Only been pulled over once in my ownership for a RBT but admittedly its on my mind a fair bit..... Just the What-If factor.
Dunno what system you have in your state but in NZ there is a Low Volume Vehicle Certificate with an inspection carried out by licensed inspectors (not the police). I just have to get driveshaft loops and then an inspection which costs $400 -$600 and then a certificate stating that all my mods are safe i.e. that the braking and suspension are suitable for (more than) the doubling of stock power, that the seats are properly secured in short that all non oem stuff is fit for the pupose. You also get a plate to go on the bulkhead and then just have to point out the plate and if necessary pull out the certificate if you ever get stopped by the cops.
Yep, we dont have anything like that. If the police pull you over they can send you to be inspected for suspicion of having modified the vehicle even if they know nothing. Read countless stories on SAU about guys having cops point out "Turbo timers" in their engine bays which are actually alarms, etc etc.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
