After driving Aarons stock example today I realized the Stagea will never be as good on the track, plus this cost me less than a manual conversion.
Aaron's jelly, I bought mine for $7k and he had to haggle the guy down to 18 grand. I won't be selling either car, I just found my new track hack. :whistling:
Definitely a better choice than tracking the bus Scotty; keep it for high speed grocery and school runs!
FYI, I can also get Emo suspension parts... ;)
Edited by Daleo
Fkn photoshop show off Dunc :P
Nah, I don't hate em either. They have a place. That place is racetrack and rally. Not stanced out in car parks with posers. And as Dale said, on the streets they look fairly ridiculous.
Everything works there, and it's a quality tool. Can't wait to see what you do with it Scotty.
I actually don't hate them at all; responsive, punchy package, and with some simple mods, they'll crush almost anything under 100k.
My mates Emo 9 has an exhaust, filter, hard pipe kit, and a walbro pump; 250awkw. It's like an angry dog, straining at the leash; just waiting to be set loose.
Less than 3k in mods INCLUDING the tune; it's gotta be good for a low 12/high 11.
The problem lies in the tens of thousands of P platers driving kitted stocker NA Lancers, and the fact that every douche in a Crummydore wants to run you; even in the Maccas drive thru.
Driving an Evo is the automotive equivalent of running through street holding a massive red dildo above your head, yelling "LOOK AT ME! LOOK AT ME!" People are looking, but for all the wrong reasons.
I hate the rear wing, and the fact that EVERYONE knows what it is. They beg to be driven hard, but if you do; everyone thinks you're a wanker.
I much prefer to tread softly, and carry a big stick.
This - all of it!
ESPECIALLY that last line. :D
i agree, im definitely not taking this down the 'hardpark' direction..
its all useless, the amount i had to do to the 200 to get it controllable again was rediculous.
I have again predicted where your car will be Aaron.
Bow down at my amazing photoshop abilities.
I can almost smell the desperation! It's just being there...
You has mad skills brah.
Edited by Daleo
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
