been slack for along time... but went camping last weekend n had alot of time on my hand when I wasn't drinking :D
n haven't put my sig thing on... new laptop :O
Edited by barraspalding
  • Replies 317
Posted Images
Love the HDR's slim, keep it up! Totes imagined you to look like that as well!! Haha.
cheers mate :D Hope that last bit is a compliment as well?? hahah
love that poster matt, looks awesome!
ah, nice Slim, love the second one, makes the building look like its a massive lighthouse, lol
Hahah yeah it does, doesn't it. I always think of zombies when i look at the picture cos, i think its just the way the guy is walking towards the camera
the two BW ones of the girl are awesome. great smile in first one. you could throw that on a wall in the familty home. the 2nd one, looks like shes meditating. which is funny because it's such an adult serious thing to do. awesome work
yeah that's pretty much how i pictured J to look too :D thanks!
Sweet shots!
Good attempt for a first HDR. Try and setup for a proper shot and try some HDR out. I like it because it looks natural and not way over the top like most are.
As Matt said, that BW portrait looks sweet Barra! Should frame that one up!
she's a 'Ballerina'... you just ask her! haha
Sweet shots!
cheers dude... think i found some easy xmas gifts :blink:
Take a single raw shot, adjust the exposure +1/2/3 stops and -1/2/3 and merge them together. Its up to you whether you get enough dynamic range out of 1 stop, 2 stop or 3 stop.
You can use photoshop and smart objects. Open the raw folder and before you press "Open image" hold shift. This allows you to re-open the same image within the image (Instead of opening the image 3 times). Then use layer masks to put the sky in, the foreground, your subjects, whatever you want! It's how i did the rolling shots above. Love smart objects!
I use Photomatix Pro for HDR's that i have bracketed for, you can also put a single RAW file in and generate a HDR image (It will ask you how many stops you want to pull it up and down). Once combined and tone mapped, i will put it in photoshop for extra treatment.
Hope i've helped you!
Edited by FST513
Mike created me a new business logo and I simply love it. If you need logos done, be sure to get in contact with him. I think his user name on here is van? Otherwise check out his website: http://localmike.carbonmade.com/
Cant wait to print some business cards now.
Opened up a random pic from today's wedding to test out the logo (still need to figure how not to cut the bottom of the text off). Will speak to mike about that one..
Anyways.. I love big bold beautiful eyes:
Edited by siddr20
hey guys,
Pics from the QLD Cruise today :( (reposted from qld thread)
Took a heap of pics, good ones are here: http://www.flickr.com/photos/33driver
Some of em:
FULL SIZE HERE
FULL SIZE HERE
Thats a nice logo man. I like it. If you want to cut the text out, just use the marque and select only the logo, cut and paste to new layer. then delete the old one. may as well save that file as logo_notext or something.
Nice shots of the qld cruise too!
here's whats probably my last 2 from the calender shoot... maybe.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
