Rad bike. Similar to mine. Used to race BMX for like 11ty years and riding a bike with different geometry just feels gay. I'll post a pic of mine tomorrow if i remember.
Anyhoo... here's a shot from texi waaaaaaaaaaaaaay back. Someone here might recognise the car... this was taken before Me and Kory had 5 minutes with it in a carpark... all alone.
  • Replies 317
Posted Images
mmmmmmmmm skids
can't wait for the next one; i'm thinking i'll bring stockies along and destroy them.
Love that shot, not sure why. Wish the DOF wasnt so shallow though, would be have been nice to get the mirror in focus.
Its my desktop picture atm. Everytime I see it I just stare at it for a while before doing anything :whistling:
I like that shot too, it works well (even though I'm not as much of a fan of R33s as I am of the other chassis).
With the DoF, you'll obviously have to shoot with a smaller aperture to get the mirror in focus too, maybe between around f/5.6 and f/8? That should still leave the car in the background with a nice bokeh effect.
The areas covered around the headlight/parker and the blinker and spotty are super-sharp, which is nice!
ooh nice - i got my first 29er the other day - loving it!! :(
ive been keen to try a 29r. thing that im worried about is tyre selection. well that and the fact i cant afford one anyway, haha.
mines just a regular 26" with 26x2.5 tyres. probably a bit too fat, but they were free and so nice skids so i'll run them till they wear out which by the look of them will be a long time, haha.
couple of pics from today...
;) made me almost fall off my bike laughing.
Pirie Street, Adelaide
Reserved parking ;P
Finally got a decent panning shot of a messenger with this Lumix. Kinda hard as im used to AF-C that focuses as you pan, so I had to guess where he would be riding and pre-focus there and hope for the best, lol.
great way to finish of a hard days work
Nick, I was using f1.8 cos I love the effect of the 50mm. I'll try lifting it up a bit and seeing how it goes.
LOL, I don't blame you - the bokeh with this lens wide open is great! I can't believe it costs less than $130. :):D
Agreed. i got my nifty fifty from ebay for $140 a while ago. Perfect for people and detail shots. so sharp and clean. DOF is mad. I was playing aruond with it last night in Nicks car as we were driving along. I'll post one up tonight.
For cars a 35mm 1.8 would be better, but the 50 is ok. just need to get back a distance if you're trying to get it all in frame.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
