Hey guys’n’girls
I’ve been fooling around with 31s for the last decade (now i feel old :) ). Around 2-3 years ago I had started to think of myself as a fairly ok drifter and not wanting to take my chances with cops in the industrial areas of Canberra, i decided to build a track only car for DA. Only thing is, as most 31 enthusiasts, I’m cheap. Enter Budget Drift car super fun build!!!
Now, 2 years later, DA dies in the ass. So the plan now is to change a few bits(better quality as well) and turn it into a relatively cheap grip car. I plan on entering Supersprints , maybe some MRA days and just kick about trackdays with friends/SAU etc.
Anyway, here is my HR31 2 door GTS that i bought early '08 down in Adelaide, got it for 3k.
Still got a few thing i want to do to it. I'm in the middle of doing the cage atm but after stuff like r32/33 rear subframe setup, splitters etc. here’s where I’m up to...
Engine/Driveline
25/30 (slapper)
ViPEC (44 i think)
JJR coilpacks
Garrett GT35r, 0.82 rear
hi-mount mani
38mm external wastegate
3in exhaust
FMIC mounted where condenser used to be
Greddy copy plenum.
adj exhaust cam gear
Walbro pump
HKS 550cc injetors
Jaz fuel cell
R33 alloy radiator
GTR thermostat, twin thermos
23 row oil cooler
Power steering cooler
31 and 32 box’s
exedy 5-puk with up rated pressure plate and Carbonic pads
single piece tailshaft
KAZZ 2-way
Suspension/Brakes
S14 HSD HRs up front
S13 G4s in the rear
JJR Adj LCAs
JJR tierod ends
Adjustable castor rods
R32 calipers all ‘round with 32 front and rear rotors
G4 hydro
wildwood brake bias adj
Earls braided brake and clutch lines
Hicas gone and Z31 sub frame bushes
Interior
Stripped of course
Nardi wheel
Some old school rally seat
4 point harness
Alloy door/quarter/rear fire wall panels
Alloy dash with speco gauges
Exterior
CSS lip and skirts
HR side and passenger vents
Reverse bonnet vent
$15 crappy mirrors (but like 200g each)
Clear front/side indicators
Alloy Ducting for intercooler and oil cooler
Lexan rear and quarter windows
C-west t-wing
Manaray 17s
pictars
new car!
Cleaned up for NSW SAU wakie day 08 (ppl may remember the Redtop eating itself)
Ebay racing
On the turps and deciding to spaypaint it with Bullet32 (Hence Grumblebee)
as it sits now (mostly)
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/
neat setup with the fuel cell :)
cheers, i just recently changed it as it was on the left and side with the pick ups facing in. at the last wakie day it would get fuel serge with over half a tank!
since taken it to a motorkana - no surge at all :rofl2:
what intake is that? (I's assuming Rb25 as well.)
do you mean the plenum? its just a greddy copy for a 25.
if you get one of these, make sure you get it pressure tested and have the face machined before you put it on.
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/#findComment-5531591
im after some suggestions on spring rates as the car is set up for drift and is very stiff
I know the fronts are 8kg/cm but have no idea about the rear, I also i think its just rears that’s the problem as im bouncing around when putting the power down.
the car weighs 1150kg with out the cage, driver and fuel so say 1330-1350kg all up, and most of the weight came from behind the A-pillar
im also running stock swaybars atm, but adjustable ones are on the cards.
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/#findComment-5533452
Just thought I'd add a few points to this thread for you James :D
Even thuough this car has been a "budget build" I have been amazed at just how well it goes, with consistent 1.10's at Wakefield (including fuel surge, slipping clutch, too much front camber and Federal 595RS-R tyres) after the work that has been done recently getting the power to a reasonable level (tuned by Glenn at ESP Racing), getting the power to the ground with some suspension tweaks, sorting out the fuel system and putting in plenty of cooling ducts for the engine and brakes, we should be able to get it into the 1.09's or lower with some stickier 'R-spec' rubber.
Here are a few more piccies of the build (hope you don't mind me adding these James) :)
Taking the old (blown) RB20 NICS out...
And putting in the new RB25/30...
Custom air guide for intercooler (oil cooler installed as well)...
Interior begins to take shape...
After about 14 or 15 beers we decide that it would be a great idea to paint the two tone bright yellow...
Not bad for a spray can job :)
The brakes looked a bit dull...
Wakefield Park (the shakedown day)...
More photos to come...
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/#findComment-5533530
cheers man
cage is nearly done and im thinking of respraying the cabin.
been thinking either all white, all black or maybe black with the cage yellow.
i thought that white might be a bit too reflective but there seems to be a lot of race cars with interiors...
Any suggestions?
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/#findComment-5541565
  • 4 months later...
ohh yeah i have a thread in here :P
not much to update really. i got the cage in, it and the interior are now black.
took it to a SOTS at wakie for some fun (round 1:10s hand timed) i think the coils are sparking out as it would start to miss something bad around 5k.
also ive order some new smaller front spacers in the effort of trying to dial out some camber. after a full day, a hole inch on the out side of the fronts were still clean! spose thats what you get for have the alignment setup for sliding pinch.gif
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/#findComment-5717277
  • 2 months later...
been doing a little bit lately. trying to get the car ready for the SAU V REACT day on the 28th. im excited :)
shortened the LCAs 20mm to curb some of the ridiculous camber, also splurged and got a wheel alignment too J now running -3.5deg camber all round, 5deg castor, 2mm tow out at the front and 2mm in at the rear
Installed some cool mirrors (cheapies, but i don't care :P )
mounted my new seat to the floor without rail as my head was being push to one side by the cage padding. Also put the fifth point in for the harness.
Got in some splitfires to replace the f**ked JJR coils. Hopefully these will hast more than a half dozen runs...
neato airbox thing
with guide
bullet32 drew me up a pic that i got made up as a sticker for the wing
hmmm thats all for now i think. cant wait for the 28th :banana:
https://www.sau.com.au/forums/topic/342805-my-hr31-buildup/#findComment-5817984
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
