  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Mini sounds good JL but is no match for backyard junk wars style Corolla engine conversions...  I'll leave it at that :D
Engine conversions are against the rules.
And yes, it will be the Lions, 4 in a row as long a Voss can stay healthy.
sweet, we made this wasteland into "...Last Page" status! Feels proud..
nexus: hmm, i'm meant to be calling you right about now aren't i? :D better get offline so i can!
Yes you are, better get me before I go to lunch for a couple of hours.
This is more like what I was thinking of, but with more *ahem* professional players :)
Why aren't the guys nude? That's a bit sexist. Females run around with their bits flopping around and the guys wear DT's. That's not fair!
Although, they look old and crusty :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
