  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nope! i'm trying to do a website proposal but procrastinating badly here..
yeah, we want classy whoring here everybody! no one word stuff :) Or i'll have to get out the whip and make you all scream like little girls
Damn its hot! Can't believe I work outdoors, time for a career change I think. Just noticed it has just peaked at 35 deg and I couldn't help but notice they have predicted 41deg for both Saturday and Sunday! Thats just getting silly.
I want everyone to check what there avg post per day is , then we can truly decide who is a post whore , and don't want to hear excuse's like ; I was away for a month etc....
I will start with my pissy little effort of about 1.2 post/day
oh yeah when are you guys going on your next cruise ?
haha, well i am, although i tend to whore right across the forums. Since i originally came from VIC and know most of the guys there, I can whore there two. I have a natural advantage :D
There is a meet tonight.. but its brisbane area.
hehe, maybe. You can easily just write one word per post. Thats not really a challenge anymore.
I dunno, I think its good to have something - encourages a more friendly atmosphere around here.. people can find out what people are like and not like.. vent pointless thoughts.. like the mosquito that I just squashed, and yet somehow it managed to crawl across the desk(??)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
