  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I had my eye on a pair of Adidas Casuals, but ended up with Some Nike ones.
What i dont get is. they had the EXACT same nike shoe, one had a blue 'swoosh' the other had a silver 'swoosh' .. i liked the silve pair. but they were $150, where as the blue pair were $80 .. and they were the exact same make and model.
Doesnt make sense to me
WTF is a puma frankenclyde?
(edit) I don't think that I could ever wear those in public.  They are VERY white.
lol....not a huge fan of white myself, thats the first pic I found
They come in all sorts of colours tho
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
