  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I had my eye on a pair of Adidas Casuals, but ended up with Some Nike ones.
What i dont get is. they had the EXACT same nike shoe, one had a blue 'swoosh' the other had a silver 'swoosh' .. i liked the silve pair. but they were $150, where as the blue pair were $80 .. and they were the exact same make and model.
Doesnt make sense to me
WTF is a puma frankenclyde?
(edit) I don't think that I could ever wear those in public.  They are VERY white.
lol....not a huge fan of white myself, thats the first pic I found
They come in all sorts of colours tho
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
