Haven't got my M35 Axis Autech yet, but i'm already thinking of what to mod on it.
Without knowing what may/may not require modification here's what I think so far (discuss!)
Must haves:
Get the english conversion on the 'TV screen'
Full service (fluids etc.)
Nice to haves:
HDI FMIC
Full exhaust
High flowed turbo
Open up the intake by removing the factory intake and making a custom version
ECU re-flash
https://www.sau.com.au/forums/topic/343401-first-thing-to-modify-on-your-m35/
i dont think full exhaust is a nice to have .. virtually an essential (well the dump anyway others will agree) if you want your turbo to last to even 100,000kms.
take a look at the dump thread.. stock dump to me is quite dangerous for stock turbos and engines its so restrictive.
but youve got the right idea tho with other mods!
Edited by PetroDola
ECU remap is impossible at this stage. i can however comment that an aftermarket one found on the yahoo auctions would be completely beneficial.
the intake is perfectly fine, its the inlet tract to the turbo that is the problem. the airbox flows well, no real point in changing it
I'm in the same boat. Question - if I get the custom dump pipe installed, I take it I cannot get a turbo back exhaust installed?
If so, is it worth going dump + cat back or just go turbo back?
Also, does branding matter much for exhaust? can anyone recommend a joint in SE Melbourne for this stuff? I live in Moorabbin and there's alot of auto shops in the area but no idea if they're any good (or know much about the M35)
1. Sway Bars
Why . . . drive around a corner at some speed. . .then you will know why. .
glad someone mentioned this.. even after hardening up my suspension im still getting too much body roll.
hard to find source it seems? you got any front and rear ?
Is anyone sourcing these , making these ? would like to find out
..dont see them often on import monster or i havent yet anyway for m35's :S
do we have one on the rear stock?
(havent even noticed really)
Edited by PetroDola
goes like this
turbo / stock dump with cat inside /2 inch + pipe middle muffler /2inch pipe + rear muffler
what you want though is
turbo / bigger dump 3inch right through to/ 3inch high flow cat /3inch pipe to high flow resonators /3 inch pipe - quality rear muffler ( fujitsubo legalis -R , S , HKS etc)
problem is though.. you cant just stick on a custom dump without removing stock cat..and having a fairly disjoined setup. (ie a stock middle muffler with no cat and issues changing that fitting later if made to suit that sized piping)
Your best off getting one thats been done.. check importmonster theres a long dump on there now suited to a fujitsubo for around $400.
then perhaps either a totally custom zorst with its own resonator and end muffler or a made one like a fujitsubo not sure if it includes highflow cat though but it looks to all bolt up to the stock turbo. a few peoples have these exhausts here.. if someone could verify!
Edited by PetroDola
goes like this
OK, so in short - custom dump means u need a whole new customer zorst setup. Or I could just get a whole new premade setup...LOL
How much is that? 1k? 2k?
How long is a piece of string?
Expect to spend at least $1500 from turbo to exhaust tip. My current system (Group buy dump, custom mid pipe, hi flow cat, Fujitsubo Legalis rear exhaust) stands at around $2000. I did it in sections, to soften the blow, and my Legalis was an ebay bargain.
Ah ok so it is possible to do it bit by bit...hmmm
So say I started with the custom dump...which other part will need to be replaced at the same time? the mid pipe and cat?
However you want to do it. You probably have multiple compliance cats to pass the emissions test. I would change the dump and front pipe first, with a highflow cat installed. The rear section can be imported or a custom muffler fitted later.
I'm local if you want a dump fabricated and fitted, or a whole stainless system... :(
I was going to leave the factory airbox in the engine bay, as I know they have nothing wrong with the amount of flow they can handle.
Sway bars is a good one for sure.
Exhaust is a tricky one. I want something quiet and preferably legal or close to in terms of CAT location.
Is it possible (without having a Stagea in front of me - damn it, to put the CAT in the dump or close to?
anything is possible.......but part of the reasoning behind doing the new dump is to move the cat away to give your turbo a bit of longevity. The standard dump is probably on about 400mm long and includes the cat. The aftermarket ones are the same length without it therefore moving a lot of the heat away from the turbo.....IMO it is better to have the cat about 1 meter at least away from the dump.
that's if you run a cat :blink:
I'm local if you want a dump fabricated and fitted, or a whole stainless system... :D
i'll vouch for that , scott makes a quality dump!, the one he supplied me is fantastic. (that he fabricated himself).
heh by the sounds of things you run a fake cat mr jetwreck :P
Edited by PetroDola
what about brake pads??
Some guys are running QFM HPX pads (road oriented), and QFM AR1M's (track oriented), GSL Rallysport on the SAU forum stock these, and do deals for members. Give them a try.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
