OK lads, I am awaiting a call from the Nissan historic department.
What questions do we want answered?
I want to confirm the total chassis.
I want to find out how many went to racing and if the GMS and GIO cars were ADM units.
The colour splits.
How many cars Nissan own if any and if they have a listing of the whereabouts of the ADM units.
How many press car were written off.
What else?
when you refer to "I want to confirm the total chassis"...is this the total number of released ADM GTR's?
this is what i want to know, as per my signature - 67 units were sold so where did the deficit 33 units finish up?
other than that, your q's cover off everything else i would like to know such as the colour splits & write offs
I guess we can conclude from the spare parts listings the changes the ADM cars got, but I would ask them if they have a comprehensive list of ADM modification to comply with ADR's......
I would also ask them if they have records confirming that all 100 cars were the same or were some factory optioned with sunroofs etc.
Do they have any point of sale from that period that we could get/buy?
Other than that, I think you have it covered. My only last comment is make sure you note down EXACTLY who you spoke to and their contact details.
Finding these guys is rather difficult at times months down the track.....
Good luck.
Bob.
Can they give group buy discounts on front lips and roof mounted aerial! :)
They don't list the roof mount aerials , I gave them a part number and nothing , but now have found them out of UK without logo but the same.
6 inch round speakers in the rear deck not 6x9
Edited by brad_gtr
If possible could the owners send me a pm with their contact details, as much or as little as you like.
Nissan are going to help with this, so get in the loop early!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
