Congrats on the purchase! Seems the flipping has occurred twice now with Shannons cars (if you count the one on carsales now from the trio that were sold).
Also your car was originally listed at 85k as OZGTR when first sold so you are still ahead :)
Guys got a question about  the adm plate under the hood, could it be wrong as there is something up with my engine number.
Block number matches the vehicle warranty and owner  identification copy. But on the aussie vin plate the engine number has a 3 instead of a 9. Rest of the numbers match
Edited by Jingpong
Ok, please be a bit more specific......
My Nissan Tag, block and my engine number in the owner's manual are all the same per attached photos.
What does yours say?
My engine number matches the owner identification copy but not the vin plate. Only one number different
Edited by Jingpong
  • 4 months later...
Hi All
I am going to sell #56 as it is not used anymore. Very good condition, just a few stone chips. 140k's. Every thing works, even the cassette deck. Thought you guys might like first go. I'm thinking $120k but if someone waved cash at me (as in $100 notes) I would consider a 10% discount.
Regards
John
Hi John,
I was only thinking of you the other day.... This poor old forum is like a ghost town now.
Everybody is now on the R32 GT-R Facebook page.
I'm a bit saddened to see you will be putting her up for sale but certainly understand where you are coming from.
Mine's been unregistered for over 5 years and been in storage since last year. Out of sight, out of mind.
Anyway, good luck with the sale but I suspect your best bet will be Carsales.
Cheers....... Bob.
Hi Bob
Good to hear from you. I think your right about facebook but at 75 years I'm not really into that. No hurry for a sale but would like it to be appreciated by someone. Not getting completely out, still got the r30 which goes far too fast for my reflexes.
Cheers
John
  • Like 4
  • 2 months later...
Hi Greg
Afraid it may disappoint. It has a couple of 6 cyl motors, two and three liter, several gearboxes, 911 brakes, Toyota steering, bits of R33 front end. Only used for sport so no trim etc. Good fun though.
I'm jealous of your 1600. Was trying to buy one when the 30 came along as a wreck.
John
  • 4 weeks later...
  • 1 month later...
Sorry John, don't get on here much! I'm not fussy about what is under the skin, in fact i love modifying. As long as the mods are executed well and improve the car then I say go for it. My biggest issue with my R32 is that I can't modify it! I think the people who have owned and put their mark on a car through it's life are as much a part of the cars story as the people who put it together at the factory. Most don't agree though looking at values of original, documented vehicles vs the modified versions.
 I bought my 1600 back in 1990 as a body and parts from an engine builder who worked at HRT and then went on to work in F1 with the Arrows team. He had started to prep the car for the track but found HRT took up prety much all of his time. Not sure where he ended up. I rebuilt it back then - it's now about 30%1600 - the rest is 240K, DR30, 180B, 260Z, Hilux, R31 - even Pulsar! Mostly brand faithful, but most of the 1600 bits are gone..
I'm now giving her a refresh, fixing up the awful job I did back in the early 90's!
But hang on this is all about ADM R32's. Did you sell your Silver car? Market was looking pretty good last time I paid attention.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
