Yeah, I am very interested to see how it goes!  Obviously this is all theory, and I think there is worth in the thought experiment side of things.
If you haven't checked them, here's the turbine flow map for the normal GT35 turbine (ie, like from your 3586HTA)
And for the "RS" version:
By Garrett's own admission/claims the increase in flow "A/R for A/R" the new RS turbine is only margainally better flowing than the existing GT35.  On paper the 1.06a/r GT35 housing will actually outflow the 1.01a/r "RS" turbine though obviously there is more to it than just that.
Edited by Lithium
Not interested in the GTX3582R GEN II, given the turbine is the same as what I've already got.
How much power does the GTW3884 produce with the 67mm-84mm comp wheel?
I think you missed the point of what I shared.... the difference in turbine flow between the old GT35 and the "RS" one used on the GTX3584RS is 2/10ths of f-all.
Based off what is available on paper I would wager than the GTW3884R will make more power than the GTX3584RS but will obviously come at some cost in terms of lag but I don't know what people have actually made from the GTW3884R.  I'm guessing something close to what people used to make with GT3794HTAs
Comparing exhaust flow between the GT35 and RS turbines at the same housing size there is a difference in flow. Okay it's not huge, about 1.5-2lbs/min at the important PR range of 3.0-3.5 where most RB motors will operate. Of course anyone willing to sacrifice even more response can use the 1.21 housing where the increase in flow over the GT35 is closer to 4-5lbs/min.
If I can get around up around 530-560kW at the wheels and peak boost by 4000-4500RPM or thereabouts I'll be more than happy with the decision.
Found a dyno result for a GTW3884 on a BA XR6T. No other details other than just over 500kW @ 25psi.
GTX35_TurbineMap.jpg&key=d1b86af86e594e8efdf3cee3ab44ab98bc5358f9501e4bedc092d544667fbd1c
GEN2GTX3584RS_TurbineMap.jpg&key=35a4320fb2bb48eda32282d583c64fe1572fd98d945576510c52bbd8b489e913
1.06 vs 1.01 isn't A/R for A/R [emoji6]
Three more XR6T with GTW3884R results:
427kW 21-22psi on 98
423kW on 19psi also running pump 98
490kW on 24psi Unknown fuel - possibly 98.
Found a 512kW on 20psi running E85 but not sure if it's a GTW3884 result or not
last one i saw was 655rwhp on 36psi through a auto sohc rb30, 144mph ish traps at 1300kg ish
What you and your mate are missing matt, is you are talking T3 housings, doesnt matter how good the turbine is..your pushing shit uphill
from 450rwkw onwards really on a 3.0...okay on a 2.0.. its t4 time if your starting from a clean sheet of paper..this will never change
your giving up spool..and power
Out of interest..the p trim turbine is hardly anymore efficient than a 3582 turbine in the real world without  being backcut alot
and the 65mm old precision turbo turbine is a turbonetics f1 wheel
Edited by jet_r31
So if the T3 housing is the limiting factor, how have people managed to run over 170mph trap speeds and the horsepower required to do so using a T3 housing?
And vls have run that close to that with 3582's with the KTS 11 blade gtx billet wheel on less boost..
my mate went 140mph on 30psi with stupid retard  backpressure(full exhaust  with gate plumbed back), others have gone 143 on 32psi.. with .82s and backcut 3582 turbines
I wonder what peak power gain I would see switching from the current FP T3 0.85 to a Garrett 1.06
463.7kW @ 25psi was all we could get using the 0.85
Saw another RB30ET make 450kW through a 2sp glide running a GTX3582 GEN I - roughly 480-490kW through a 5sp on the BW dyno
Yeh my mates vl made 450rwkw though glide on 30psi with just that 67mm comp wheel upgrade on 3582 ..went 140mph
make f**kloads more with exhaust off...but went straight to 40psi...and maxed out 2 044's
laggy though...
you really want a pt6466 .82 t3..
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
