Yeah, I am very interested to see how it goes!  Obviously this is all theory, and I think there is worth in the thought experiment side of things.
If you haven't checked them, here's the turbine flow map for the normal GT35 turbine (ie, like from your 3586HTA)
And for the "RS" version:
By Garrett's own admission/claims the increase in flow "A/R for A/R" the new RS turbine is only margainally better flowing than the existing GT35.  On paper the 1.06a/r GT35 housing will actually outflow the 1.01a/r "RS" turbine though obviously there is more to it than just that.
Edited by Lithium
Not interested in the GTX3582R GEN II, given the turbine is the same as what I've already got.
How much power does the GTW3884 produce with the 67mm-84mm comp wheel?
I think you missed the point of what I shared.... the difference in turbine flow between the old GT35 and the "RS" one used on the GTX3584RS is 2/10ths of f-all.
Based off what is available on paper I would wager than the GTW3884R will make more power than the GTX3584RS but will obviously come at some cost in terms of lag but I don't know what people have actually made from the GTW3884R.  I'm guessing something close to what people used to make with GT3794HTAs
Comparing exhaust flow between the GT35 and RS turbines at the same housing size there is a difference in flow. Okay it's not huge, about 1.5-2lbs/min at the important PR range of 3.0-3.5 where most RB motors will operate. Of course anyone willing to sacrifice even more response can use the 1.21 housing where the increase in flow over the GT35 is closer to 4-5lbs/min.
If I can get around up around 530-560kW at the wheels and peak boost by 4000-4500RPM or thereabouts I'll be more than happy with the decision.
Found a dyno result for a GTW3884 on a BA XR6T. No other details other than just over 500kW @ 25psi.
GTX35_TurbineMap.jpg&key=d1b86af86e594e8efdf3cee3ab44ab98bc5358f9501e4bedc092d544667fbd1c
GEN2GTX3584RS_TurbineMap.jpg&key=35a4320fb2bb48eda32282d583c64fe1572fd98d945576510c52bbd8b489e913
1.06 vs 1.01 isn't A/R for A/R [emoji6]
Three more XR6T with GTW3884R results:
427kW 21-22psi on 98
423kW on 19psi also running pump 98
490kW on 24psi Unknown fuel - possibly 98.
Found a 512kW on 20psi running E85 but not sure if it's a GTW3884 result or not
last one i saw was 655rwhp on 36psi through a auto sohc rb30, 144mph ish traps at 1300kg ish
What you and your mate are missing matt, is you are talking T3 housings, doesnt matter how good the turbine is..your pushing shit uphill
from 450rwkw onwards really on a 3.0...okay on a 2.0.. its t4 time if your starting from a clean sheet of paper..this will never change
your giving up spool..and power
Out of interest..the p trim turbine is hardly anymore efficient than a 3582 turbine in the real world without  being backcut alot
and the 65mm old precision turbo turbine is a turbonetics f1 wheel
Edited by jet_r31
So if the T3 housing is the limiting factor, how have people managed to run over 170mph trap speeds and the horsepower required to do so using a T3 housing?
And vls have run that close to that with 3582's with the KTS 11 blade gtx billet wheel on less boost..
my mate went 140mph on 30psi with stupid retard  backpressure(full exhaust  with gate plumbed back), others have gone 143 on 32psi.. with .82s and backcut 3582 turbines
I wonder what peak power gain I would see switching from the current FP T3 0.85 to a Garrett 1.06
463.7kW @ 25psi was all we could get using the 0.85
Saw another RB30ET make 450kW through a 2sp glide running a GTX3582 GEN I - roughly 480-490kW through a 5sp on the BW dyno
Yeh my mates vl made 450rwkw though glide on 30psi with just that 67mm comp wheel upgrade on 3582 ..went 140mph
make f**kloads more with exhaust off...but went straight to 40psi...and maxed out 2 044's
laggy though...
you really want a pt6466 .82 t3..
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
