2 hours ago, Lithium said:
Nice!! Cheers for sharing :). More or less what one would expect, as you said.  A few hundred rpm laggier too by the looks?  And this would be on an RB30?
No problem.
Yeah I was hoping it wouldn't really loose anything down low but definitely did. However you wouldn't really know it to drive, and the plan was to try some E in it too.
Yes, 25 headed 30.
Really really interesting how much... Or little difference the  a/r change made.  Is this a divided setup?
And crikey - this looks like it's going to end up being a complete animal.
Yeah for sure. I started off with a .7 AR then .8x then 1 and came on earlier each time.
First time it has lost a little down low, but comes on hard!
Yes divided.
Nice, really interesting results overall.  What is the difference between the blue "E68" and the green "E68 boost earlier" curves?
655kw @ wheels isn't messing about at all, should be hell of a fast car there :)   The spool looks better than a few of the GTW results I've seen, quite cool to see a 25 head being used for something of this kind of power-  is it still VCT?
Blue had more WG duty from the start and really cold day.
Have not really seen any other results except I do have a GTW 3684 on a 25 I have graphs on.
Has everything there for VCT but not running currently, on my list.
Good power!  But yeah, solid point @Dose Pipe Sutututu - its what, 100kw at 4000rpm???  That is possibly the least power I've ever seen from an RB30DET at those rpm! :O
Edited by Lithium
  • Like 1
It's a dedicated drag car but running H-pattern for something a little different.
9.81 @ 142 with high 400s. New set-up should go a fair bit quicker.
More boost still to come. Plan is up to up it to around 40psi.
  • Like 2
Good power!  But yeah, solid point [mention=22311]Dose Pipe Sutututu[/mention] - its what, 100kw at 4000rpm???  That is possibly the least power I've ever seen from an RB30DET at those rpm! :O
Not a DET [emoji6]
See original post.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
