looks like Mr Newey has set the trend once again. So far, all challangers have a variation of the RBR nose with the slight dip throughout, with that slim bottom for the diffuser
Cant wait to see what Mclaren have done. The car always looks so fcuking cool
It was an interesting time when the regs changed and all the cars came out completely different. Who was going to set the standard for what all future cars where to based? Well it turns out Redbull are the guys to emulate. so, time for a regulation change?
I think it'll suit most cars on the grid, especially Lotus. The only exceptions would prolly be Mclaren, Williams and Mercedes
Small price to pay. The white sidwalls will always look the sexiest and we did have a goor run. Everybody thought the green strip on the softs would look stupid as hell, but you get used to it. The pis of Pirelli yellow and super soft green tyres on the run will look pretty sweet i think
I think it's just due to the fact that they always print their 'logo' straight across. it's usually quite small and the same colour as the tyre so of no consequence but now that it's huge and yellow it looks a bit stupid. If they don't want to bend their recognisable logo they should just leave the P-Zero bit on the tyre and make the cars run the pirelli logo somewhere on the barge boards or something instead of on the tyre.
Sheet cant upload photos for some reason. but i got a whole lot from racing underground. the redbull car looks the goods. their rear wing and front are a little different from others
got some nice high rez images.. might try upload them someother way.
either resize them (I think the max for the site is 1200X1200) or upload and link them via imageshack etc.
Yer i thought that was it..
here goes! i got 3 folders full. heres a few.. they have most of the other cars there also.. and a few videos of Fernando coming off on track..
some nice lookin bits on the rb7.. the gills on the rear end plates look sweet. along with them extending the body fair way back to the wing.. i dont think the others did it for this year..
Looks little different from those shots. Some tweaking of the front wing design.
Has the fduct tho.. so that would be last years model? i got some good photos of it and thought it looked slightly different on the wings..
the virgin cars however.. wooh wooh wee waaaahh!! look pretty aggressive
decided to do a few. these are track photos, as i've not downloaded each teams folder..
Force indian doesnt look like its changed much, williams looks like its going to morph into a submarine, schueys mercedes looks sweet..
the rest well you decide!
post-31456-0-53295100-1296684188_thumb.jpgpost-31456-0-90459600-1296684204_thumb.jpgpost-31456-0-46559200-1296684220_thumb.jpg
post-31456-0-60393500-1296684233_thumb.jpgpost-31456-0-32725500-1296684248_thumb.jpgpost-31456-0-16536000-1296684289_thumb.jpg
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
