Or maybe just harden the f**k up.
It's not netball, the racing is actually supposed to be the pinnacle of contests ( and challenges)
Basically, nothing good as come though regulation changes for about 20 years Except the reversal back to non grooved slick tyres.
Every time the FIA have a chance to really fix the sport they f**k it up.
God I'm such a whinger.
Not whinging, you're just thinking along the same lines as many millions of f1 fans around the world.
Edited by Galois
I wonder how the world media would have reacted if a steward said "they penalised Hamilton because he was black....that's what Ali G says....I am just kidding".
They hit him with a powder puff anyway, 20 second penalty which cost him nothing.
Roy is spot on, if he said the track is tight and opportunities are rare as hens teeth. In both cases the drivers left the door ajar but closed it before I could complete my move.
He will be great to watch in Canada.
There's also 54 billion chickens in the world*
*[citation needed]
im tipping Canada will be an absolute cracker... overtaking will be making its comeback
I concur, Sir; Hopefully they've now crunched enough data on where to place the activation lines to ensure we get to see lots of ballsy braking zone battles
Haha, here we go, the thing I've noticed about commentary is that no one is ever happy, people SCREAMED to have martin on the BBC team without James Allen, who I think was too distracted with the contours of Lewis Hamilton's Asshole.
There is no one out there who will do as good a Job, personally I like the inside Line and the banter between Coulthard and Brundle and the anecdotes add spice.
I really dislike commentary that is ridiculously over the top and emphatic like in NASCAR.
I sort of see Brundle in the same light as Mark Skaife in the V8SC.
+1 for Martin.
Brundle has been losing his shit for a while now. Rambles on all the time and misses some of the most blatantly obvious stuff. Can see him being phased out soon
Seemed to serve Murray Walker alright for about, oh, 17,000 years or so.
Damon Hill'd prolly be a decent replacement at some stage, yeah?
Theres a bit of talk about moving the barrier that the Sauber hit, but i dont think thats the issue. That bump in the road that they hit just as they enter the breaking zone seems to be the cause of all the problems.
I mean you can even see it if your just standing there on the road looking down the hill. Imagine how it looks and feels for the guys driving over it. Surely a cheap easy fix would be just to smooth that thing out and all should be well, no? Why go to all the trouble of moving cranes and barriers
It's part of the charicter of the track, doing stuff like that is how we end up with tilk tracks. It's the most prestigious race to win, it's not meant to be easy. Being a temp street circuit it would probably be easier to move the barrier anyway.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
