I've been saying that since the mid 90's and here we are lol.....
my new formula would be:
3.0 Litre DOHC 5 valve per cylinder max twin turbo V10.
Or upto 8 Litre naturally aspirated, any configuration.
Free aero, apart from front and rear wing wake and air disturbance massively reduced.
Full ground effects floor, tunnel and diffuser allowed.
No kers or any other device of this nature.
alcohol based fuel.
minimum two tyre manufacturers.
cockpit equalised so that no driver is held back by weight or size.
Larger tyres, much different profiles, probably 18"
If full ground effects were allowed back (sliding skirts, tunnes... etc) the cars would have tiny wings anyway, regardless of rules.
I think the old 1.5 turbo or 3.5 na is the way to go, but leave the piston count and layout free. The turbo tech that would come out of low capasity engines would be great
by the looks of the rule changes...i dont think i'll be watching after 2013 anyways. so they can all do what they like
good point. I figure if I up my alchol consumption by about 30% I will soon forget all the WDC results from 1985 to 2000 and I can then just re-warch those 15 years of F1 over and over again...
yeah agreed. 3l turbo and 8L na is waaay too big. get them to make a max 1.5L turbo or 3L na as the maximums. they can easily get 800hp-1000hp from either 1.5L turbo or a 3L v10 NA so then they get to chose reliability (800hp) or power (1000hp). or spend more and have both!
if really generous up it to 2L turbo and 3.5L NA. that is plenty.
I like the idea of cockpit rules though and perhaps raise min weights so that fat drviers aren't penalised! lol. i'm sure there's some talented fatties out there... would surely help webber to be on an even keel weight wise with vettel. he is giving away probably half a tenth per lap in body weight penalty alone.
....actually the way Raikonnen is going on the tooth he might need an extra widebody F1 car if he makes a come back.
I wonder what mods they made to get Tony Stewart in the MP4-23 did they graft the A to B pillars from a BA Falcon with a seat located in the middle to fit him in? It would have left room for space to sit a pizza, a couple of burgers and cupholders for a big gulp.
I would love to see more taller/bigger drivers have a shot at F1 but realistically it is a sport for rich midgets.
alcohol based fuel.
then i'd def be watching. :)
sadly.....very unlikely
I'd be happy to keep the current capacity, what is it 2.4L? They can make plenty of power from that capacity these days. But allow whatever configuration they want to run as far as how many cylinders etc, and have no rev limit.
It could give some more variety in the field, the way its going it will be a common pretty much everything ala V8 Supertaxi's in a few years.
No rev limit could potentially reward teams willing to push the limits of engine reliability if they can hold them together. I don't see the problem with that because they already get penalised for using too many engines anyway, so why not let them push the envelope of reliability?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
