love seeing the little clouds appearing off the sides of the rear wings on the straights.
and we're off to a commercial break. just what we need while it's still wet..... and we missed schumachers radio message. oh great and we have to watch some stupid music shit.... not even ads for products, we have to watch lame promotion of another show
It makes perfect sense, just like Ferrari should do for Massa.
It's Webber's fault for f**king the start/first lap so bad
i know it makes sense. but they brought him in too early, which was sort of my point. but even if webber was in the lead they'd still bring him in as the test dummy
Yes and no...1 lap early maybe, considering he's setting the fastest lap now, and right in time considering Vettel would come in a lap or so after him, being the ideal time with the top 4 drivers pitting
who else thinks that redbull will pull webber in, put slicks on webbers car to see how they perform so they know when to put them on vettels car?
Well called. We've seen an early move to slicks work for Webber before too, don't forget
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
