love seeing the little clouds appearing off the sides of the rear wings on the straights.
and we're off to a commercial break. just what we need while it's still wet..... and we missed schumachers radio message. oh great and we have to watch some stupid music shit.... not even ads for products, we have to watch lame promotion of another show
It makes perfect sense, just like Ferrari should do for Massa.
It's Webber's fault for f**king the start/first lap so bad
i know it makes sense. but they brought him in too early, which was sort of my point. but even if webber was in the lead they'd still bring him in as the test dummy
Yes and no...1 lap early maybe, considering he's setting the fastest lap now, and right in time considering Vettel would come in a lap or so after him, being the ideal time with the top 4 drivers pitting
who else thinks that redbull will pull webber in, put slicks on webbers car to see how they perform so they know when to put them on vettels car?
Well called. We've seen an early move to slicks work for Webber before too, don't forget
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
