Schui backing up his awesome drift from germany in turn 2 here
Redbull struggling these days. Bit of a brawn v2.0? they better have something after the break otherwise their quali advantage will vanish, and vettel is truely fcuked if he wants any more race wins
at least we might not see his stupid finger too much more, and if we're really lucky he might hang himself from the rafters
Ricciardo is making some ground on Di Ambrosio and is in front of Liuzzi. Good progress for him this race.
He's making genuine progress and doing it pretty quickly. He was hoping to be close to Liuzzi at the end of the race and he's doing better than that. Another race or two and he may begin challenging the Virgins
my guess is lap 45 we'll get another
spoke to soon.
and what's this. onlt 1 more ad break after this one in the last 25 laps of racing? i don't believe them, lol
actually on second thoughts, they will probably just make it last 10 laps
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
