triple pack $906 - $1,110
but its cheaper to get a quad package.
quad pack $794 - $947
both thursday to monday
both 4 corner brabham
have a look
Edited by tweety bird
Biddy?
:yes: i could see her at turn one just as the f1s approach start to talk about something completely irrelevant.....
i wouldn't call myself a mummas boy, i spent most of the days on the weekend telling here to gtfo. :laugh:
she still does not know if she coming yet anyways.
more from schumi
Hello my tifosi chums.
You, more than anyone else in this crazy world we call F1, will be knowing what the situation is right now with a certain line of questions.
"Michael, are you going to retire?"
You know, if I had one euro for every time this question has been asked to me, I could have given it to the Greeks and they would have no debt problems. It was last year very similar.
There are three totally boring and most-asked questions in F1 and that is one of them. The second is "Do you think Lewis is a dangerous driver?" and the third is, "Eddie, is that your own hair?"
The answer to each is "no", "no" and "no".
I am also constantly being asked what I think about Sebastian, to which I always reply with a bit of a wink attached: "I think he's the best Swiss driver since Clay Regazzoni". Which reminds me. Quite honestly and obviously there is something to be investigated about Italian surnames in F1. Perhaps there is a genetic link as to why there are so many who don't come from Italy. Let me start a list for you:
Rubens Barrichello, not from Italy, from Brazil
Jerome D'Ambrosio, not from Italy, from Belgium
Paul DiResta, not from Italy, from Scotland, och aye
Daniel Ricciardo, not from Italy, from Australia, mate
Sebastien Buemi, not from Italy, from Switzerland
Jarno Trulli, not from Italy, from Planet Whiney
The last entry was, naturally, a joke, but you can see where I am pointing. Anyway, I am very much enjoying my summer break here at Schloss Schumi in Vufflens Le Chateau. It has given me time to reflect the season so far. Perhaps my two nemesis are doing the same. I am sure Kamui Kobayashi is doing something relaxing, like hurling himself down canyons in a damp suit. Vitaly Petrov is no doubt at a Black Sea resort gorging himself silly on beetroot-based snacks. Probably some insects, too.
Quite honestly and obviously and honestly and obviously my season would have been a lot better if they hadn't been in the way so much. But it is my own fault. I keep forgetting things. I wake up at night in the cold sweat screaming "Unlatch the paddle! Unlatch the paddle!"
There are so many buttons to press and it is always so difficult to remember what they do in the heating battle. Lieblings pudgie wudgie donut face says I can't remember to put the top back on the toothpaste tube at home so it's not surprising I fiddle with the wrong buttons when I have 'Banzai Boy' or 'Simples' breathing up my exhaust pipe.
My starts are going great. No problems there. It's just my finishes that are not going so well...And Laps 8 to 46 could also be a lot better.
Here is the typical race for me in 2011.
Qualify two places behind Nico, 0.2 seconds slower. Not so bad.
Good start, make up a few places
Change tyres the earliest on Lap 12
Emerge from pits behind Kobayashi who's going to Lap 27 on one set and my DRS wing isn't working. Stuck behind him, strategy disappearing down drain like a rat chasing a sausage.
Banzai Boy disappears and finally catch Petrov.
Lose front wing in excitement of catching up another car
Box for new wing.
Come out in front of leaders and have to slow down to be lapped
Lapped by Nico... who waves to me
Press all buttons on the steering wheel at once to try to get the car to break down
Car breaks down
Give my "cheery battler" smile and wave to crowd on way back to pits
Prepare excuses for interview with Lee McKenzie who will ask me, "So, Michael, how did it go...?"
I will hint at a problem from Lap 7, but make little of it
I then say I'm really looking forward to the next race.
And no, I am not retiring.
That is the first part of the season over, but already I am looking forward to the second part and my favourite circuit at Spa and the power of the Mercedes engine. With some nice improvements to the car we can make it to the podium in the next two races. I am certain of this. I just hope the improvement doesn't involve another button.
Until then my little Schumsters, have a great summer break and if you see any strange or fascinating insects while you are out in the hot sun, make sure to send them to Vitaly, but please, whatever you do, don't send him the brightly coloured ones as they are often poisonous...
The Schum
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
